Ok, here's the problem. I have developed a miss in the 390 that resides in my 65. Feels like a dead miss, but with the installation of a new ignition (pertronix) and new plugs it is still there.
So here are the options I am left with.
1) Bent pushrod (again)
2) ignition problem
3) fuel problem (need to replace old fuel filter)
So, what do you guys think?
Moose
About to give up
About to give up
American born, German blood, Texan attitude..... And people wonder why they call me "Moose."
66 F-100 Too much to list
05 F250 The Tank
05 F250 The Tank
- 6166 Junkyard Dog
Like the previous posts , check compression, Bent Valve, Burnt Valve, Crack in the valve seat, Bent push rod, low compression on a cylinder Try this while running take a spark plug that is loose, hook a wire to it and see if the electrode is firing remember to ground out the plug so you can see it is firing or while running pull 1 plug wire off at a time to see if the engine sound changes, Good Luck
Now Cooper will try his best
