99-02 Jeep Liberty Seats
I bought a pair of these seats that are powered and heated from a member here and was going to use them in my 66. The brackets are not even close to the floor in a 66 so I am having to make my own brackets which I already expected. I am using angle iron and cut the stock ones down to size but I am wondering if anyone here has done this with these seats and what they did. I welded the drivers side up (not done completely yet) but still not too comfortable with how they are looking. They will work but I'd still like to see some other idea's if they are out there.
Thanks for any help/ideas!
- Clearcreekcustom66
Shawn i am just going to throw this one out there. what if you use 3/4 square tube and then cut some gussets weld on the inside of each joint. if you knock the corner going on the welded joint you can leave your bead and then t weld the two tubes together. it would be stronger then angle and look cleaner in my opinion. jason
When i start laying black streaks - they start leaving brown ones.
1966 F100 cc 352 soon very soon 351w
Oh ok I see what your saying. Thanks a lot for that info. The only problem here is that the way the brackets on the seat are now I can't do something like that. Well maybe I can but it would be VERY hard. The side bracket is like a big flat plate and the other side (inside) is a weird bracket like thing that I cannot cut and weld a square tubing to. Hard to explain without seeing it. I will post pictures next week of what I have now. I was going to stop on this part of the project and put the stock seat back in for now but today I went to get the stock seat from under the house and now there is mold all over it and it smells horrible and ripped all up. I started on the passenger side and hopefully this week I get the welding part done and start drilling the holes in the floor of the truck to mount them. Then I have to wire the seats all in (which I don't look forward to).
- Alan Mclennan
- dotcentral
Shawn, don't know if I mentioned this before, but those seats are used in other Chrysler products. The Dodge magnum wagons use the same seat, porbably with different seat brackets. Could be other Mopars with them as well. Not to send you on a wild goose chase, but maybe a different bracket would fit your floor?
Or if you need something temporary, I think used bench seats are 30-35 bucks at pull a part. If you want to go I can help you with that one.
- Alan Mclennan
- Alan Mclennan
For some reason the seats don't look the same underneath. Did you have a bracket on the outside of the seats that kind of looked like it had crooked ladder steps on it like a ladder? I think three of them?
Let me try and get a picture of mine either later today or tomarrow and post mine. If I can do mine like that then even better for me because mine sit a bit high and I just dont like how they look.
- Alan Mclennan
Shawn, I really cant say what the brackets looked like originaly I know that I cut some pieces off and bend another, must be having a grey moment!.but yes you do have to watch the height it`s amazing how much room those seats take up I`m only 5`10 and it does`nt leave a lot of head room but it does give you a good view of out front. I also used the centre console from the jeep and their the only non FORD parts in the truck,did you get the wire harness with the seats no problem if you did`nt just the plugs make it easy to connect when the seats are in.
Alan
Alan
Alan, sorry I totally forgot about this thread and haven't even gotten time to get pictures of my seats yet. I am hoping to do so tomarrow when I get pictures of some headers and a dirt bike I will be selling. Anyways, no I do not have a wiring harness just the wiring and plugs under the seat. That part is what I am going to need to try and figure out. As for a middle console I will mold my own out and make it flow nicely down and from the dash to the back and make it flow with the sides of the seats (same contour) and wrap it in the same color leather, etc.
- Alan Mclennan
- Alan Mclennan
Shawn,I had a look at mine and the power wire is red with grey marker and black is earth on mine I have a painless wiring kit and I used one of the power window circuits for the seats.You could use the accecories circuit or hook into the power feed to the fuse panel and have a inline fuse for protection,but make sure what ever you do have constant power to the seats so you can operate them without the ignition on.I`m sure one of the other members could advise you better on the finer points of wireing(and probably spelling)than I can .
Alan
Alan
Ok thanks a lot. How about wiring the heated part? They have one of the plugs (male or female I cannot remember) but the other side isn't there so I will have to make a plug. Are your seats heated as well?
I really appreciate the help here, I do not plan to wire them up yet since pretty much everything has gone on hold for a while until I get a new job but I will be writing this down and looking it over so I know what to expect when I get into it.
- Alan Mclennan
Ok well I will figure that out someway then. Yeah I will find something I am sure. I have looked a little but then again I dont know if I want to keep working doing auto body and painting, maybe try something else out... I am trying to do some side work right now and have a golf cart to custom paint, airbrush and pinstripe but I am not really making anything on that at all.
Well again, I appreciate the help!
