gas leak
Casey 65
gas leak
Post by Casey 65 »
Hey Guys, need some help. the gas fitting on my carb is seeping again. I've tightened it several times and it's seeping again. (gas dripping on the manifold) I'm afraid I'll strip the threads in the carb if I keep tightening it. is there a sealant I can use on this application?
GLindley
Thread Tape
Post by GLindley »
Can't say as I've used this stuff on a gas line, and I'm not sure of its resistance to gasoline..
Click
here
Gene
1961 Intregal cab SWB 223 (getting 302 & TIB)
1969 LWB 302 automatic (Donor for the '61)
2000 F150 XLT SWB (Daily Driver)
Casey 65
Post by Casey 65 »
They have a tape for gas lines, but no retail sales. I'll call around. thanks.
ELpolacko
Post by ELpolacko »
If it is a Holley carb you can get a new gasket for the inlet adapter to fuel bowl at any parts store.
If it is leaking between the steel fuel line and the inlet adapter you will most likely need to re-flare the steel line and replace the inlet adapter.
These are cheap and easy repairs, don't mess around.
cdherman
Post by cdherman »
Gerry -- what carb you running? I have lots of YF and some 1101 parts. I have a fiber washer that I used to stop a similar leak with my 1101 that had loose threads.
PM or email me if you want to come over and troubleshoot/swap some parts on this weekend.
dch...
1683
Planned/considered upgrades:
Casey 65
Post by Casey 65 »
Thanks David, I'll plan on driving by this weekend :D
