4-speed swap
doc
4-speed swap
Post by doc »
Any big surprises when swapping in a 4-speed (no-granny, non-truck performance style) into a '66 w/ a present 352/3-on-the-tree?
The truck will lose all haulin' duties (I have an F-250 HD for that) & just be a cruiser of sorts.....
Thanks!
Doc
'66 F-100 Custom Cab
352/3-tree, red/white, LWB
Comet
Post by Comet »
Depends on which tranny you go with, but generally there is enough room in these to put almost any tranny in. Just might require some fabbing of cross members if unusual.
adrianspeeder
Post by adrianspeeder »
What four speed non granny you talkin about?
The T-18/19 and NP-435s have granny lows
(does the NP even have an available FE bell???)
No go on the five speed M5OD and ZF trannys
Adrianspeeder
Comet
Post by Comet »
Yes, the NP 435 was offered on FEs for years.
adrianspeeder
Cool, I'll update my tranny page info.
Adrianspeeder
doc
Post by doc »
I wouldn't swap in a M5OD tranny in my worst enemy's truck...had my fill of those w/ two trucks. ZF is a nice truck trans, but not swapping in a 429/460 or small block now.
I was thinking toploader 4-speed (non-overdrive) as the truck will just be a cruiser from now on.....
I found the info needed yesterday on another site.
Thanks!
Doc
mcarlson11
Post by mcarlson11 »
You guys want a manual tranny that has the best of all worlds??
Here it is:
an NV4500 manual 5 speed
1st is a granny low, like the NP435, and 5th is an overdrive. This can be bolted up to an FE with a bellhousing adapter.
http://www.nv4500.com/product_info.php/ ... s_id/24307
65 F250 Custom cab, camper special. 352,4spd floor shift, dana 60 posi lock, power disc brakes in front, power steering, and fun to drive.
