My 65 f-100 2 wheel drive, was originally an inline 6 with a 3 on the tree. It now has a 289 with a c4. I am planing on going to a 4spd out of a Granada, 4th gear being overdrive! I only piece of clutch linkage I have at this point, is the clutch pedal resting on the firewall.
I'm am helping a friend part out a 1964 f-350 dually, 2 wheel drive, inline 6, with a T 18.
Will any of the clutch linkage pieces from the 64, bolt in and work on my 65?
If not, what year and model of trucks do I need to look for, for a donor, so I can have all factory bolt in clutch linkage parts?
Manual clutch linkage parts interchange?
Simon
65 f 100
65 f 100
Re: Manual clutch linkage parts interchange?
No experts on clutch parts?
Does anyone have a picture of what the clutch linkage parts look like installed on a f-100, 2 wheel drive, twin I beam truck?
A few pictures from underneath, of the frame and at the tranny where it all connects would be nice.
Simon
65 f 100
65 f 100
- slixtyfive
I will take a look at what I have and try to post something back later today.......
EDIT:
I should clarify - I don't think they will interchange but you might be able to make them work with some modifications. But I have both so I can take look and get some pics today.
EDIT:
I only have the 61s, and am not sure they would be the same, I do have some of those parts since I went with hydraulic clutch. My son has a 66 but it came with an auto, so no help there
- slixtyfive
They are different and although they could probably be modified to work, I'd think finding the correct parts shouldn't be too hard. As I suspected, it looks like they are the same for bumps and I should have an extra set from a bump if interested(let me know as i'll have to dig through some boxes to confirm that I have it).
The bracket at the frame is different and its difficult to tell this in the pics but the '63 (top two pics) pivot assembly is larger - both the length of the pivot shaft as well as the length of the arm going to the clutch arm. Bottom two pics are my '65. However, as I'm typing this it came to me that the engine could also impact the size of the pivot shaft and clutch arm. These are both 6 cyl (but different vintage 6 cly - 223 vs 300(EDIT: should be same as your 289)). As you can see, the arm for the clutch pedal rod to connect to is at a different location left to right in the truck so apparently the rod from the clutch pedal comes through at a different location. I believe I have another setup from a bump with a 390 so I'll try to find that for comparison also.
Thanks slixtyfive. So if I'm looking at this right, on the early clutch linkage, the rod from the pedal runs on the outside of the frame rail, and the later linkage runs on the inside of the frame. Is this correct?
Simon
65 f 100
65 f 100
- slixtyfive
Yep - basically. I'm not sure if the early one actually would clear the outside of the frame but its right over the outer edge (above the frame).
