Smallblock clutch linkage
66camperspecial
Post by 66camperspecial »
I am thinking about taking the 460/C-6 out of my 66 and installing a 302 and 4 speed toploader back down in it,I know the windsor motors were never installed in those trucks from the factory so if I decide to do this so will the 67 to 72 smallblock parts work.
bigmcgiv
Re: Smallblock clutch linkage
Post by bigmcgiv »
if our talking about the z bar. i oud get the 67 stuff and tweak it. honestly it a tube with 2] 1/4 inch bent bars not much to it just time consuming. get pics for reference. headers will make it more of a issue.
you will need parts from the 69-72 truck.
the 6 and 302 use a screw in ball on the side of the block. all the others have a bracket with the ball mounted to it.
not sure if you need to move the frame bracket some or not.
look at lower left corner
66camperspecial
I should have all the original clutch parts but they are for a FE but was curious about the Z bar.
tomrooster
Post by tomrooster »
Frame bracket fits as is . Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
66camperspecial
I need to look in the shed and see what i done with the parts i took off 5 years ago,probably would be easier to go to the junkyard and get other parts.
