C6TE-C Exhaust Manifold Collector & Doughnut
chris401
Post by chris401 »
Welding and redrilling manifold outlet and building exhaust from scratch, need part numbers or sources for flange, studs and doughnut gasket or correct dementions. Would I just need to ask for a 66 F600 to get factory parts?
chris401
Re: C6TE-C Exhaust Manifold Collector & Doughnut
Post by chris401 »
Will anyone with a good manifold give me correct center to center stud measurements on exhaust outlet?
Mr. Jones
Post by Mr. Jones »
What engine do have? I have a 352 manifold,driver side,passenger side uses a different donut.Will measure it if that's what you need..
chris401
Post by chris401 »
Mr. Jones wrote:What engine do have? I have a 352 manifold,driver side,passenger side uses a different donut.Will measure it if that's what you need..
It would be on a 391, Industrial 428 etc. The same manifold for right or left. Here is a picture of a reproduction.
mrgoob
Post by mrgoob »
Not the best picture. Looks like 2 & 15/16". Be able to get more accurate tomorrow if you need.
chris401
Post by chris401 »
mrgoob wrote:Not the best picture. Looks like 2 & 15/16". Be able to get more accurate tomorrow if you need.
Yes, I would appreciate that. Are yours 3/8 studs? Each manifold has been welded, tapped, redrilled and drilled crooked again.
mrgoob
Post by mrgoob »
Best I can measure center to center 2.96".
Stud measuring 0.433" on the threads, 0.44" on the smooth.
Hope that helps. Show us some pictures.
chris401
Post by chris401 »
Thanks mrgoob. I'll post before and after pictures once I repair them. Here is a manifold reproduction source I found.
http://www.stevensparts.com/FORD%20EXHA ... NIFOLD.htm
