Lmc rear tank
chris401
Re: Lmc rear tank
Post by chris401 »
61ford wrote:http://www.lmctruck.com/features/fb/FB31A.htm. this is Interesting that they are actually making stuff for our trucks. This is actually the same tank as they sell for 67-72 c10. They send no instructions on how to install it but what I've seen with the Chevy you don't have to move the rear crossmember. I've just been looking for an option bc I don't want a filler neck in the floor
I have a behind the seat tank from LMC. Had it for a while before it was used. In this case the flare inside the tank where the line screwed in choked down to 3/16". With the stock 2 barrel 352 it was unnoticeable. When I changed over to a hotter 390 there was a fuel delivery problem. A 7/16" pickup with a 3/8" line to the pump fixed it.
