New bed floor
Ttnc
New bed floor
Post by Ttnc »
Have the channels and have the wood. Next week I'm gonna cut the edges and drill the holes. Bed should look much better than the ground when you look in.
Re: New bed floor
It's a job that's actually easier than it looks
A second pair of arms does help though ...
I would recommend one thing....
The bolts that go thru , that don't go thru an original brace....
I made a strip out of 3/16" x 1 1/4" flat steel
Drilled holes every 6" or so ..& used it instead of just the washers
Here is a pic of the bottom
Notice the original braces , plus the extra ones I built
These added strength & stiffness
Without any excessive weight or modifications to original bed
Very cheap & anybody can make it with simple tools
oldsmiley
Re: New bed floor
Post by oldsmiley »
Looks like it worked out well for you. Great job. I love to see people do things themselves, rather than say "I CAN'T DO IT".
A person can usually do anything that they WANT to do..... you just have to WANT to.
Ttnc
Re: New bed floor
Post by Ttnc »
Well, after cutting, planing, dadoing, staining an sealing the white oak i have finally put some wood in the bed. Still a few holes to drill and bolt down, but its pretty much done
tomrooster
Re: New bed floor
Post by tomrooster »
Pictures, Please
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
