1992-1996 ford bucket seats in a slick?
aj64f100390-292
Post by aj64f100390-292 »
Ive thought about this for a while... my main concern was not whether it would fit...brackets shiuld take care of that but how well it fits in the 64..steering wheel wise and all, but i do want to move my steering column up like te 65 65, using a 61-64 column mount, by cutting it down and moving it as close to the bottom of the dash as possible..anyone done that? Anyone got pics of these seats in a 61-64, or experience with at least setting them in? My plan was to have some reopolstered in a more slick style material with the v8 hood embelm or something..
19mpg hwy, .040/298ci, arnd 8.7:1, ECG heads, stainless valves, ceramic coated ramshorn manifolds, B code int., eddy 4bbl, Durasprk II/C5ZF dizzy, C2AE rods,high ratio rockers, NOS two groove h.balancer, unkwn cam-for now :twisted: soon:pwr asst steering
Re: 1992-1996 ford bucket seats in a slick?
I put buckets in my '64 and I had to adjust and readjust....and adjust them some more. I am 5'-6" and I'm still looking for more room (and I'm not fat either - 155 lbs.) I want to do the same with my column. But I understand that the shaft in the column runs straight into the steering box and if you raise or lower the column in the cab, you would either put it in a bind or put undue stress on the column bearings. I have thought about cutting the column tube in the engine bay area and also the shaft, then angle the column up and use a double-D joint. This would be the 'poor mans' version without having to buy a tilt column. I have been pricing tilt columns and they are expensive. Btw...I love the bucket seats...it was just an issue of getting the height just right.
I was going to post pics....(stupid photobucket is not working correctly).....
Anyway....I'm watching to see and learn....
aj64f100390-292
SteveCanup wrote:I put buckets in my '64 and I had to adjust and readjust....and adjust them some more. I am 5'-6" and I'm still looking for more room (and I'm not fat either - 155 lbs.) I want to do the same with my column. But I understand that the shaft in the column runs straight into the steering box and if you raise or lower the column in the cab, you would either put it in a bind or put undue stress on the column bearings. I have thought about cutting the column tube in the engine bay area and also the shaft, then angle the column up and use a double-D joint. This would be the 'poor mans' version without having to buy a tilt column. I have been pricing tilt columns and they are expensive. Btw...I love the bucket seats...it was just an issue of getting the height just right. I was going to post pics....(stupid photobucket is not
Right, ive thought about trying to look for some ford van tilt columns that were the exact sane size as the 61-76 columns, im not a fan of the aftermarket columns ive seen...look like chevy to ne and dont look right...but dad and i had a thought about mopar columns dare we say it...he thought that if he remembered right some were pretty close to te ford columns, but i havnt decided on wheather to use the toyota gear box, or rebuild my power assist control valve or fab up the 65 and later gearbox either way it will get a rag joint and some sort I f break away system...but ive been thinking about swaping the 65 and up floor pan in later...and leaving the main stuff a 64 and down style..for room but i dont know my floors are good now but far from finished..but they will last a long time now the way they are..uts hard to do all that when your dailying your truck to high school lol..without good planing haha
aj64f100390-292
Or dailying it period for that matter, its not my only source...i just prefer to drive it if at all possiible...hehe
I've heard of the " Econoline tilt column conversion" for years, and have yet to see one which appears a likely candidate! If you find any specifics, I'd be interested. As to using the later slick floor pans; it's not an easy task, and still offers no help with the fore/aft steering box action. I shy away from modifying a column; a replacement tilt column ofers the only solution, IMO, since I readily admit to my larger girth and height. No matter what I have tried, non-tilts end up in odd positions in my experience.
FarmMotorSports
Post by FarmMotorSports »
I've done the Double D joint on my 61.
I did it, so I could do a body lift. I needed some upward room for an Allison trans.
If you look closely you can see the joint, and a tie rod boot from a semi as a dust seal on the box.
I used a 68 column tube and lower bearing. The top is all original 61...
61 F250 Unibody
5.9 Ford Diesel / Allison
Disk brake straight axle
i like my mustang style buckets. been in my truck 16 years, could use new skins but to me are very comfortable
ras4434
Post by ras4434 »
I put Bronco seats in my 65 (same really as mustang) and a CHEVY (ya I know) tilt column from a van. Both worked good. I did cut down the tilt. I am 6' and 320 on a good day and this is my daily driver cuz I love it.
Ross Swearingen
1965 F100 "MIKI"
aj64f100390-292
ras4434 wrote:I put Bronco seats in my 65 (same really as mustang) and a CHEVY (ya I know) tilt column from a van. Both worked good. I did cut down the tilt. I am 6' and 320 on a good day and this is my daily driver cuz I love it.
sounds nice, ya idk my dad sounded like he was saying that there were some later van that used a nearly identical column...but ill have to clarify, but if your 6 and 320...im goning to be honest its not bad for me but if tye seat went back farther id be alit better for foot room...im 5' 9 145 lol in hs.. but my goal is to do what i can to have things looks stockish...while being a nice daily driver...
aj64f100390-292
FarmMotorSports wrote:I've done the Double D joint on my 61.
ca yopost some picjs of the inside, so you have a tilt column in your '61?
aj64f100390-292
ya ive thought about just doing some of those and do it up in a ranger kinda style...but with that being said to e whats nice about the 92-96 bucket seats is that theyre a very nice package: lumbar, console doubles as a bench seat ,and when i put my fuel tank on the frame, and get a fuel door on the quarter panel, i think it will open up alot on interior mods, like the door pressure release vents the newer trucks have and then add on storage back there...one mod at a time though..
Last edited by aj64f100390-292 on April 26, 2017, 8:27 pm, edited 1 time in total.
You are going to have to add joints into your system. You could just shorten the steering column tube, cut the shaft, and add a d-joint that would allow you to move your current column closer to the dash. The other thing you could find is a dent side tilt column.
aj64f100390-292
bruceandersson wrote:You are going to have to add joints into your system. You could just shorten the steering column tube, cut the shaft, and add a d-joint that would allow you to move your current column closer to the dash. The other thing you could find is a dent side tilt column.
ya, there is 73-76 tilt column s that are the same size as mien, i always wondered, as i have a 73-76 turn siginal unit in mine for the built in 4 way switch, i havent seen one yet..but im sure theyre out there ..just gotta find one i guess
FarmMotorSports
Nope, no tilt. Just one double D u joint at the steering box.
It's still a straight solid column. Looks stock inside.
But, It could use any column now, that the shaft isn't a solid part of the steering box.
It is just a first step toward using any column I would want in the future and gave me the flexibility to lift the cab without putting the column on a bind.
61 F250 Unibody
aj64f100390-292
FarmMotorSports wrote:Nope, no tilt. Just one double D u joint at the steering box.
OK, Nice cummins you have stashed in your slick...looks good :thumright:
aj64f100390-292
while I like how they look...To be honest honest I really like the 90s center console...and the lumbar, headrest and all...but those seats do look good.
aj64f100390-292
what buckets did you use?
Masterguns
Post by Masterguns »
I really want to use the 50/50 split bench seat from the 85 crown vic LTD donor car. they are in mint condition, and probably some of the most comfortable seats I have sat/driven in. I have searched the internet, but haven't found any one that has done it yet, so if I can make it work I'll try to share how they work out.
Semper Fidelis
1961 f100 Unibody BBW
2002 Excursion 7.3 (the bus)
1982 Bronco
2017 F150
2017 Mustang GT/CS
aj64f100390-292
Masterguns wrote:I really want to use the 50/50 split bench seat from the 85 crown vic LTD donor car. they are in mint condition, and probably some of the most comfortable seats I have sat/driven in. I have searched the internet, but haven't found any one that has done it yet, so if I can make it work I'll try to share how they work out.
sounds cool, let us know how it works out, keep us updated
aj64f100390-292
Image...ya I know my battery was low :D
