Rookie Question: 1963 223/240 To 1965 300 Interchange
chris401
Post by chris401 »
A man with a 1963 F100 I6 2wd 3 speed is looking at swaping to a 1965 300 I6 from a 2 wheel drive.
Question: Will there be any problem with mating the cast iron engine mount/timing cover from the 63 to the 65 engine? Will the 65 cam gears clear the 63 timing cover?
slixtyfive
Re: Rookie Question: 1963 223/240 To 1965 300 Interchange
Post by slixtyfive »
I'm no expert on the I6 engines but the 240/300 are the same basic 'architecture'. The 223 is totally different.
Yep ... The 223 has different bell housing pattern
And different engine perches than the 240/300
bobenhotep
Post by bobenhotep »
I swapped a 63 F100 with a 223 over to a 300. The transmissions and bell housings are different. The good news is that the 240/300 has a lot more options for transmissions and bell housings.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
bobenhotep
Also, forget using the mount from the 223. It won't work. I used a bolt in crossmember for a FE engine to get mine in.
"The Iron Rhino"
-duraspark II/ HEI
chris401
Post by chris401 »
I sent him this post and he says he is a member here. I will let Randy tell first hand more about his truck.
