Fuel sending unit?
creedua
Fuel sending unit?
Post by creedua »
I have googled for the past hr. Does anyone besides LMC carry a fuel sending unit for a '64.
bobenhotep
Re: Fuel sending unit?
Post by bobenhotep »
http://dennis-carpenter.com/fuel-tank-s ... TZ-9275-K/
https://www.npdlink.com/store/products/ ... 50532.html
I don't know how much shipping is on either, but check them out. dennis carpenter is generally considered to have good stuff. I have had good luck with NPD as well.
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
64 f100
Post by 64 f100 »
Your local parts house should be able to supply you with a fit all, that can be adjusted to work on your truck. You may have to ask for a later model unit for like a 79 with in cab tank. I assume there were some with in cab tanks in 79. I stated before in a post that if you have ever had one of these apart, you will wonder how these worked at all past the first time used.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
creedua
Post by creedua »
bobenhotep wrote:http://dennis-carpenter.com/fuel-tank-s ... TZ-9275-K/
64 f100 wrote:Your local parts house should be able to supply you with a fit all, that can be adjusted to work on your truck. You may have to ask for a later model unit for like a 79 with in cab tank. I assume there were some with in cab tanks in 79. I stated before in a post that if you have ever had one of these apart, you will wonder how these worked at all past the first time used.
Thank you sir, I'm sure they all come from the same Chinese factory, but I hate paying LMCs shipping. I ordered the one from NPD.
