Bad power brake booster??
Xx
Re: Bad power brake booster??
3 choices
hose leaking
fitting in booster on hose cracked/leaking
booster itself is gone
have someone operate the brakes while you look/ listen under the hood
hose leaking
Probably fluid leaking internally
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
I had a feeling the booster was bad. I have noticed I have to apply more pressure than usual when I use the brakes. I will have to give everything a good look tomorrow.
Thanks, Don
Thanks, Don
Well, I finally was able to take my truck for a drive (the last 3 days, it wouldn't start) to test the new larger brake booster. I am really surprised and pleased at how good the brakes are now. The pedal goes down slightly more but when the brakes take hold, you know it.
