Window crank knob
creedua
Window crank knob
Post by creedua »
How do I remove the original knob on the handle? Already have the handles off. I have tried everything that I can think of. I guess its a BFH next.
Day 2
Re: Window crank knob
Post by Day 2 »
If the knob is going to be reused, I used a little heat from a heat gun and warmed up the back of the pin pretty good, and used a wide blade screwdriver to pry it off, if your not reusing just cut it off.
64 f100
Post by 64 f100 »
The pin in the back is a press fit, and hard to get off as you have noticed. It has ridges on the pin that are tapered towards it's end so it can go in easily but not come back out. Wondering why you want to take the knobs off?
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
