Autolite 1100 air cleaner ?s
Posted: August 14, 2017, 4:48 pm
by Zax63
Does anyone have any pics of how the 1100 attaches to the stock air cleaner? Or suggestions for an aftermarket setup? I found a good 1100 and have it mounted and the truck finally runs. But I have no air cleaner and i'm not having much luck finding one, or making some kind of adapter. I have the air cleaner that was on the crappy Carter that came with my truck, but the opening is a half inch too big and there is no lip on the 1100 for it to rest on if I made an adapter.
Re: Autolite 1100 air cleaner ?s
Posted: August 14, 2017, 7:52 pm
by ThinLizzy13
This is only pic I have at the moment. It's the stock oil bath filter. It just sits on top with one screw down the middle to hold it in place.
Posted: September 11, 2017, 4:36 pm
by Zax63
I have a lead on an air cleaner from a mid 60's F100 with a 240. Looks close to the pics of the 223 air cleaners. Does anyone know if it will fit? Does the 240 use an Autolite 1100?
Posted: September 11, 2017, 6:54 pm
by ThinLizzy13
Stock 240 should have an autolite. Air cleaner opening is roughly 2 1/8".
If you need the mounting bracket on top of the carb still, I believe champion carburetors has them for about $20.
