Measurement and Info needed
Posted: September 12, 2017, 6:09 pm
I'm not sure on all years but thinking 61-66 f350 steering wheel may be the same? I need someone that has one to measure the circumference at the largest part of the wheel before it drops down to the metal column itself.
The 65 I'm working on had a late 70's f150 automatic column but discovered last night it's a tilt column. I've also got another column from a manual transmission truck and might try merging the two to get close to a mid 60's factory appearance with the tilt function. I think I've got it figured out, but need to know the diameter of the four spoke f350 steering wheels. If close to same diameter, I hope to get a big wheel with a tilt.
Thanks for your help,
Bradshaw
Bradshaw
