It is currently January 23, 2018, 2:41 pm.
Post new topic Reply to topic  [ 7 posts ]
Author Message
 Post subject: Steering column
PostPosted: September 13, 2017, 11:11 pm
Offline
My 66 needs a steering column. Does anyone know if a 67 column is the same? :D
Top
 Profile
 Post subject: Re: Steering column
PostPosted: September 14, 2017, 6:16 am
Offline
I can't say for sure, but have used columns from dentsides in slicks so I suspect everything up to '79 should be able to work with a little work. The dentside columns need to have the mounting flange moved from a slick column added in place of its flange. The 73 and later power steering columns are a little shorter and can provide a little more room behind the wheel.
Top
 Profile
PostPosted: September 14, 2017, 7:46 am
Offline
National Flag: Canada
Is there a way to mount a slick steering wheel onto the dent side column? I know it may look a bit goofy because the center section of the slick wheel is smaller than the original dent side wheel.
Nic
Top
 Profile
PostPosted: September 15, 2017, 6:12 am
Offline
The slick steering wheels fit just fine. The collar parts are all interchangeable.
Top
 Profile
PostPosted: September 15, 2017, 6:49 am
Offline
Images: 255
73-79 COLUMNS Need several areas to be done to,, re-wiring steering column due to more wires on 73-79 than a slick,, NEXT 3 spoke steering wheel fit BUT NOT THE HORN RING, until you cut off about 3/4" of end of the shaft so horn ring will fit,, also 77-79 columns are more dangerous in a truck due to they only have a junkie hard seal to hold those columns in the trucks with 2 dash to column bolts,, As where 73-76 has the actual clamp to firewall bracket with a better inside seal but that clamp will fit 77-trucks, Now mid 74 to 79 trucks have that Junkie lower plastic bearing cup in which is junk, unlike the 73 to mid 74 has the better lower bearings
column interchange to be Politically right but others can be adapted
65-66
1966 Bendix Power steering
67-69 non power steering
67-69 Bendix power steering
late 69 Ford Box
1970 Power Steering
1970 non power steering
71-72 Power Steering
71-72 non power
73-76 Power Steering
73-76 non power
1977 only Power Steering
1977 only non power
78-79 Power Steering
78-79 non power
_________________
Slickstock,,, Kansas City, KS
Top
 Profile Personal album
PostPosted: September 15, 2017, 3:12 pm
Offline
Well I better take a closer look at it. I couldn't get the wheel to engage the splines on the column. It was as if it wouldn't drop down far enough.
If I can't figure it out I will post some pictures.
When I took the 73-79 steering wheel off I noticed there was an oversized nut underneath of the proper nut acting like a spacer. It didn't look factory :roll: Maybe something is messed up with my column.
Nic
Top
 Profile
PostPosted: September 15, 2017, 7:47 pm
Offline
Images: 255
regardless any year,, only should be the wheel and a nut,, but what I have seen some of these people doing to steering columns would not shock :shock: me
_________________
Top
Who is online
Users browsing this forum: Bing [Bot], Gary Seymour, Google [Bot] and 1 guest
Search for:
Jump to:
cron
