It is currently January 18, 2018, 6:26 am.
Post new topic Reply to topic  [ 17 posts ]
Author Message
PostPosted: October 11, 2017, 5:24 pm
Offline
Images: 0
My 350 is the shop for some tune up work,Jack calls me today and says #1,2,3 cylinders are reading in the 450 degree range and that #4,5,6 are showing a temperature in the 200/250 degree area measured on the exhaust manifold,using a thermal measuring device. I told him to proceed with a compression test and call back tomorrow.Also had a Pertronix Ignitor installed with Flame Thrower coil.Engine was down on power and my tune up last week did not help much that's why I let the pro's have a go at it ........Any thoughts on a condition like this??
_________________
Top
 Profile Personal album
PostPosted: October 11, 2017, 9:17 pm
Offline
Images: 4
Sounds like a coolant flow problem
I had a dodge that had a piece of tin tube in the head
If it wasn't installed, coolant didn't flow in the back
Not sure if a 300 has such a device
Weak water pump ?
450 sure seems extreme though....
Can't hardly believe that type of heat
_________________
Top
PostPosted: October 12, 2017, 11:33 am
Offline
Images: 0
At those temps, sounds like you have some cylinders not working well, or at all. I’d be looking toward a common problem affecting those three cylinders, assuming common manifold.
Spark plug condition should have provided a clue; compression check will pretty well tell the tale as to mechanical integrity. That leaves the FAST part of the CFAST equation! Got the C(ompression), that leaves the Fuel, Air, Spark, Timing:
_________________
Top
PostPosted: October 12, 2017, 1:00 pm
Offline
Images: 0
Do you have the later style two piece dual exhaust manifolds on it?
_________________
'87 F150 XLT Lariat 300 3spdOD
'03 CVPI
Top
PostPosted: October 12, 2017, 5:55 pm
Offline
Images: 0
Not split,the old style one piece......how might that play into it??
_________________
Top
PostPosted: October 12, 2017, 6:39 pm
Offline
Images: 0
I was just taking a shot in the dark that *maybe* if you had the split manifold then *maybe* the front three cylinders' exhaust was plugged somehow.
This is a real head scratcher...did your mechanic have any suggestions after your compression test?
_________________
'03 CVPI
Top
PostPosted: October 12, 2017, 8:45 pm
Offline
Images: 4
Are you running a 2 bbl carb ?
Could one side be running leaner ?
_________________
Top
PostPosted: October 13, 2017, 6:10 am
Offline
Images: 0
Called Jack back yesterday,cancelled the compression test....$85.00hr.The engine runs better than when it arrived so I'm getting it home and do that test myself.....that won't be until next week..Will post the results then and at their hourly rate the comp.test money will buy a decent infrared detector........meanwhile I'm open to all info....
This post is in a state of temporary suspension........I'll be back........
Pat,Brandon and Paul thanks
_________________
Top
PostPosted: October 13, 2017, 9:31 am
Offline
Images: 4
I bought a cheap detector from harbor freight
I ain't a fan of Chinese stuff
But it was only like $30
Works ok.. red laser dot ,not very bright
Digital readout kinda small
Not for a mechanic that would use it everyday
Ok for somebody that rarely uses it
_________________
Top
PostPosted: October 13, 2017, 10:01 am
Offline
I would check timing on the 4th cylinder in rotation which I think is 6, it should show the same as 1 if different a broken cam could still be turning but be a few degrees late.
Of course this is from the SWAG method.
Johnny
_________________
Top
 Profile
PostPosted: October 17, 2017, 3:43 pm
Offline
Dan, this isn't the one you recently did a light freshen on was it?
Top
 Profile
PostPosted: October 17, 2017, 6:00 pm
Offline
Images: 0
Robb,
That one was in my 66 250,this is the gray 350 we rode in at Salina....
_________________
Top
PostPosted: October 24, 2017, 12:38 pm
Offline
Images: 0
Got a call from Jack,Friday.Told me they found a broken valve spring on #4 making it run really cold,so that was pulling heat away from 5&6 .....picked it up a couple hours ago drove it to the job picked up all the extra material and returned those drove back to the job unloaded all the trash outta the 250 into it,should have a couple tons in by quitting time......The shop installed the Pertronix,adjusted the valves and a tune up adjusted carb......engine is so smooth at idle it's hard to hear,tested it on a long steep hill made power all the way up....spent the last two weekends doing brakes on the 250 and it's done.Fiqure between what I did myself and the shop both jobs cost me about $460.00 each I'm happy with that
_________________
Top
PostPosted: October 24, 2017, 1:11 pm
Offline
Images: 13
National Flag: Portugal
Good to hear, would like to find a mechanic that does not charge over 100.00 dollars an hour, and actually knows how to work on these. All I can find are high dollar...low knowledge type r and r shops.
_________________
viewtopic.php?f=32&t=18944
Top
PostPosted: October 24, 2017, 2:44 pm
Offline
Agreed, it is becoming a lost art. Asked about points and distributors at a local O'Reilley's parts counter and see what you get. Deer in the headlights. Actually had a kid working the counter tell me he knew nothing about how they worked or how to look them up. When you hear that you walk out the door and try and find a better parts counter guy.
That's great news Dan! Glad your girls are back up and running good.
Top
 Profile
PostPosted: October 26, 2017, 4:00 pm
Offline
Images: 0
Good deal, Dan, gotta love the modern technology. Back "in the day", the thermal measuring device consisted of a body part!
i do miss the old diagnostic scopes, though!
_________________
Top
PostPosted: December 3, 2017, 7:56 am
Offline
Images: 9
Sigh......., I remember when anything built after 1948 I considered a "late" model. What happened?
_________________
Top
Who is online
Users browsing this forum: Bing [Bot] and 5 guests
Search for:
Jump to:
