It is currently February 25, 2018, 10:56 am.
Post new topic Reply to topic  [ 15 posts ]
Author Message
 Post subject: Headlight switch stuck
PostPosted: November 6, 2017, 11:48 am
Offline
The plunger on my headlight switch will not pull out at all. Anyone else ever run into this? Anybody have an idea how I can get the switch out without destroying something?
_________________
'63 F100 Wrongbed
Top
 Profile
PostPosted: November 6, 2017, 9:52 pm
Offline
Images: 1
Will the shaft still rotate? Or has the entire assembly froze in position?
My first attempt would be a healthy dose of lube thru any openings I could find.
Let soak, wiggle, worm, soak and repeat.
I've had terminals burn up causing the plastic to adhere to the moving assembly.
The only cure for deformed internals is to disassemble from the back side.
Remove wiring, find the tin ears that retain the plastic parts, pry them back.
It depends on how burnt up it is , on if parts fly or need forced apart.
Good luck
_________________
61 F250 uni
Top
 Profile Personal album
PostPosted: November 7, 2017, 10:59 am
Offline
Good luck
It does still rotate and even clicks when you spin it counter clockwise to turn on the interior light. But it does not budge at all when you try to pull it out.
_________________
'63 F100 Wrongbed
Top
 Profile
PostPosted: November 7, 2017, 12:04 pm
Offline
Images: 11
are you sure you are pushing down on the release button? i assume you are trying to turn on the headlights? shoot some lubricant on the button if you can.
jim
_________________
1966 F100 SW 428CJ C6
1965 F100 SW 428 TL
1966 F100 SW CVC 428CJ C6
1965 F100 SW CVC 428CJ C6
1966 F100 LB RANGER 390 C6
1965 F100 SW CVC 460PI C6
1972 F100 RANGER XLT SW 428 C6
1967 F100 SW CVC 521 C6 UNDER CONSTRUCTION
1967 F350 390 4 SPEED
1970 F350 428 4 SPEED
1974 F350 428 4 SPEED
NUMEROUS PARTS VEHICLES
Top
PostPosted: November 7, 2017, 12:24 pm
Offline
You've got a tricky problem, normally the answer would be take it out - but you cant take it out without pulling out the knob and shaft. The switch was available from NAPA as of a few years ago and is definitely available from suppliers as is the know and shaft. I'd disconnect the battery, and spray wd40 or similar in and see if it frees up. If not then I'd use large channel locks to destroy the plastic part after pulling the fuse block off to try and save the knob and shaft.
Top
 Profile
PostPosted: November 7, 2017, 1:02 pm
Offline
Images: 0
Simply pull the shaft out as far as possible, clip it off as close as possible to dash, unscrew the retainer nut, and remove the switch. More than likely, you will be able to remove the remainder of the shaft by playing with the release button while using pliers to pull on the shaft.
_________________
Top
PostPosted: November 7, 2017, 1:05 pm
Offline
Images: 0
Note that there are two different lengths of replacement shafts and knobs, so, if possible, determine which you have. Both fit, one.just sticks out about a quarter inch more.
_________________
Top
PostPosted: November 7, 2017, 2:24 pm
Offline
Images: 13
National Flag: Portugal
When you say it will not pull out at all. are you saying the shaft will not come out of the switch, or you can not pull it out enough to turn on the head lights, just rotate it left and right to turn on interior lights?
_________________
Top
PostPosted: November 7, 2017, 2:59 pm
Offline
Guys, it's not that I can't pull the shaft out of the switch. I can't pull the switch out at all. It is stuck in the off position and will not even pull out a millimeter.
_________________
'63 F100 Wrongbed
Top
 Profile
PostPosted: November 7, 2017, 3:35 pm
Offline
Images: 13
In that case I would buy a new switch/knob. Cut or break off the knob, unscrew the old and swap it out.
_________________
Top
PostPosted: November 7, 2017, 5:17 pm
Offline
Images: 0
[quote="Zax63"]Guys, it's not that I can't pull the shaft out of the switch. I can't pull the switch out at all. It is stuck in the off position and will not even pull out a millimeter.[/quote
What John said! That sometimes indicates a broken rheostat insulator, still requires replacement.
A little extra foce might save some effort.
_________________
Top
PostPosted: November 13, 2017, 1:02 pm
Offline
Got it out. Had to pull the knob off and use vice grips. I didn’t want to destroy the factory knob but now that I see the amount of pitting it wasn’t usable anyway.
_________________
'63 F100 Wrongbed
Top
 Profile
PostPosted: November 13, 2017, 2:04 pm
Offline
Images: 13
Glad it worked out, hope you saved the shaft so you know what length to get for the new switch
_________________
Top
PostPosted: November 13, 2017, 6:10 pm
Offline
Yeah, I still have it all. The switch appears to work now that it is no longer stuck. But with the obvious moisture issue I still think I should replace it. Are there multiple switch types as well?
_________________
'63 F100 Wrongbed
Top
 Profile
PostPosted: November 16, 2017, 9:57 pm
Offline
Images: 0
Yes, but '61/'64 F100 and F250 all utilize the same switch.
_________________
Top
Who is online
Users browsing this forum: No registered users and 3 guests
Search for:
Jump to:
