It is currently January 17, 2018, 12:41 pm.
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: Headlight switch wiring
PostPosted: November 24, 2017, 5:37 pm
Offline
Please forgive my ignorance for electrical work but the light switch on my 63 is kicking my butt. I've read the wiring diagrams and I've found the hot in and the headlight out. Beyond that I can't find a single hot post on the thing. I'm doing all this with the switch just hanging there. Does the switch need to be grounded for the other controls to work? Connecting a factory switch to a rebel harness. Thank you in advance for all that take the time to help me. This is kicking my butt
Top
 Profile
PostPosted: November 24, 2017, 5:56 pm
Offline
Images: 0
I’m not an electric guy by any means but I have had other switches do funny things when not grounded properly. I would try grounding it and see if that makes a difference. The switch should ground itself when its installed in the dash.
_________________
'87 F150 XLT Lariat 300 3spdOD
'03 CVPI
Top
 Profile Personal album
PostPosted: November 24, 2017, 6:47 pm
Offline
I'll give that a shot in the morning. This is tough lol
Top
 Profile
PostPosted: November 25, 2017, 8:25 pm
Offline
Images: 1
I don't think grounding the switch will matter, it's allowing 12v to travel thru to the bulbs. You might have the wrong wire for putting 12v in. It would be easier to check with a continuity meter. If you have a volt meter google it . It's not to hard to do. Tom
_________________
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
Top
PostPosted: November 26, 2017, 9:25 pm
Offline
Images: 0
I'm thinking power flow on the early switches is thru piggy-backed fuse block, then back to switch for all but headlamps. I'll check if I have any old versus later switches in stock. The guy at Rebel should be able to answer that, however.
_________________
Top
Who is online
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
Search for:
Jump to:
