Seatbelts - new aftermarket or wrecker
mercuryv8
Post by mercuryv8 »
So I priced out some seatbelts on "seatbelt planet". Then got to thinking maybe I should just get a set from the wreckers out of a newer pickup, maybe something like a dent side truck. I don't want anything fancy. A black 3 point belt for each side and a black lap belt for the middle. I would like an all steel buckle of similar style to my 62 unibody.
What would you guys do? Aftermarket or start watching the wreckers?
Nic
*Edit*
Aftermarket belts are going to be just over 200 USD.
Re: Seatbelts - new aftermarket or wrecker
I bought new belts.
Here’s the thing about wrecker belts- I looked..
Some wrecks were bloody.
Some were cut.
Some were greasy.
To each their own..
FarmMotorSports
Post by FarmMotorSports »
I plan to use the Andover company's belts.
http://www.andoauto.com/index.html
Probably the plain T-bird non retractable lap belts.
http://www.andoauto.com/TBird.htm
We had a set of these belts in a Studebaker when I was a kid.
Simple and almost indestructible, easy to use.
I'm not a fan of late model belt setups, retractors fail, latches get stubborn, just plain poor quality.
If I stumble across a set scavenging a wrecking yard so much the better.
61 F250 Unibody
5.9 Ford Diesel / Allison
Disk brake straight axle
jamesdfo
Post by jamesdfo »
tomrooster
Post by tomrooster »
I bought seat belts out of a wreck and installed them and didn't like the way they work then bought new ones and put them in and there pretty good . If you want the wrecker ones you can have them just pay shipping. There tan. Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
6166 Junkyard Dog
Post by 6166 Junkyard Dog »
we get many trucks in with belts,, BUT we cut them for the reason we do not want to be responsible for people's lives ++ no telling how many I had to cut to get people out of their belts cause they jammed on them
12649
chris401
Post by chris401 »
mercuryv8 wrote:So I priced out some seatbelts on "seatbelt planet". Then got to thinking maybe I should just get a set from the wreckers out of a newer pickup, maybe something like a dent side truck. I don't want anything fancy. A black 3 point belt for each side and a black lap belt for the middle. I would like an all steel buckle of similar style to my 62 unibody.
Nic
*Edit*
Could be thin up top. A customer rolled and totaled his then one year old 1992 F-250 SuperCab. The 1986 cab that was used had the shoulder brace bolt in a different spot. The original owner had it 10 more years and the second owner set it out to pasture a couple of years ago. Every time I saw it I thought of those big washers I put behind the shoulder mounts.
