305/70 tires on 10” wheels
Posted: November 28, 2017, 7:43 am
by Blackwaterforge
Is anyone running 305/70 tires on 10” wheels?
Any rubbing?
What back spacing?
Thank you!
Re: 305/70 tires on 10” wheels
Posted: December 2, 2017, 9:42 pm
by BarnieTrk
Sounds pretty tall and wide to run up front - likely will rub when you make a tight turn, BWF.
They likely would be fine on the rear though..........
BarnieTrk :2cents:
Posted: December 3, 2017, 12:09 am
by FarmMotorSports
No I haven't ran that size.
Yet...
33" high
12" wide
8.5" side wall
I don't see a problem sucking in a 8.5" side wall 1" per side.
As for clearance. I'm betting for frame interference at full steering lock.
It's only a 2mph increase @65 over a 265 75 16
Is the gear ratio not working out with the new motor?
Posted: December 3, 2017, 7:33 am
by Blackwaterforge
This would be for the rear.
Fronts are 235/85 R 16
I want something that will fill the wheel wells but not rub.
I have 7” inch rims now and would like to run 10” on the rear.
I have a 4.10 rear end but I have purchased a 3.54.
33” tires should put RPM’s around 1950 at 70 mph
Posted: December 3, 2017, 11:10 am
by jamesdfo
BWF: Do you have an overdrive top gear?
Because when I do the math for 33" tires with 3:54 axle ratio @ 1950 RPM, I get 54.1 MPH?
But adding a GV .778 OD into the picture gets you to 69.54 mph
James
EDIT: I had to go look in your Cummins swap thread, but found the answer:
"I also have a Watson 3 speed auxiliary that I will be using."
So there's the answer:)
Blackwaterforge wrote:This would be for the rear.
Posted: December 3, 2017, 1:14 pm
by Blackwaterforge
Yes
55 mph around 1950 rpms in fourth gear direct.
70 mph around 1950 in fourth gear direct.
I think I am going to go with 285/75 R 16 tires on 8” rims.
I think they will be easier to put on a full floating axle.
I appreciate y’alls input.
