It is currently January 17, 2018, 12:59 pm.
Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: Gas tank removal
PostPosted: December 23, 2017, 6:56 pm
Offline
Images: 7
I'm trying to get my tank out is there 2 bolts on the back side at the bottom
_________________
Ryan
61 Ford f100 Unibody short bed
351w/Aod
Top
 Profile Personal album
 Post subject: Re: Gas tank removal
PostPosted: December 23, 2017, 8:27 pm
Offline
The bottom had a lip and the top has 3 or 4 bolts. I just pulled the tank in my 66. It may get caught in those bottom lips and be a pain in the butt.
Top
 Profile
PostPosted: December 23, 2017, 8:31 pm
Offline
Images: 7
Ok I thought there wasn't but the way it was tugging when I was trying to get it out it acted like it had bolts I'll go by to pulling
_________________
Ryan
351w/Aod
Top
PostPosted: December 24, 2017, 12:06 am
Offline
Images: 4
A second guy helps ... but one guy can do it
_________________
Top
PostPosted: January 9, 2018, 9:22 am
Offline
Images: 70
The bottom sets in a metal piece bolted to the floor with the frame mounting bolts for the cab. You need to take the filler neck out and most likely the robber hose off the tank so you can slide the tank to the drivers side and remove it from the cab out the passenger side. Kind of tricky even with the seat out. I believe you have to lean the tank forward at the top, then raise the tank off the lower supports to get it to come out. The seat has to be all the way forward.
Top
PostPosted: January 9, 2018, 10:49 am
Offline
Images: 0
A small pry bar works wonders. Place it on the floor at the end of the tank, pry it upward, then do the other end the same way. Sure will save your back, and cut down on the swear words.... :cussing:
The Bible says in:
James 3:10
Out of the same mouth proceedeth blessing and cursing. My brethren, these things ought not so to be.
Top
Who is online
Users browsing this forum: jkimbrel65 and 2 guests
Search for:
Jump to:
