It is currently April 26, 2018, 8:33 am.
Post new topic Reply to topic  [ 7 posts ]
Author Message
PostPosted: February 6, 2018, 5:57 pm
Offline
Images: 0
is there any big differences in a 61 Dana 44 rear end vs a 64 Dana 44 rear end? I know they should still bolt up but the parts catoloug goes from 64-72 so I figured somthings may hve changed but that probably just where they stopped and started I guess.
_________________
19mpg hwy, .040/298ci, arnd 8.7:1, ECG heads, stainless valves, ceramic coated ramshorn manifolds, B code int., eddy 4bbl, Durasprk II/C5ZF dizzy, C2AE rods,high ratio rockers, NOS two groove h.balancer, unkwn cam-for now :twisted: soon:pwr asst steering
Top
 Profile Personal album
PostPosted: February 6, 2018, 6:02 pm
Offline
Images: 0
I may be picking up a Dana 44 from a farm 61 unibody, and when and if I use I will want a 3.25- around that ratio what ever is close in Dana ratios if their different- and keep the locker. my dads a nine inch nut so he has no clue, as far as if I can swap a part or the whole gear set, clutches and all that.
as always thanks in advanced.
_________________
Top
PostPosted: February 7, 2018, 3:49 am
Offline
Images: 0
The big problem is likely to be the ratios. D44 "case break" is 3.73/3.92. Thus, if your donor setup is 3.92 or higher numerically, it takes a different carrier for a taller gear. There are exceptions, aftermarket gear sets are sometimes available to increase that "break" range. I don't know of any which would bring the ratio down to the low 3's, however. So, assuming your chosen donor is 3.92 or higher numerically, by the time you purchase all the needed parts including carrier and gear set; you likely can find a donor 9" and set it up with limited slip more economically.
:2cents:
_________________
Top
PostPosted: February 7, 2018, 12:32 pm
Offline
Images: 70
I have a 65 Dana 44 posi out of a 65 that had an automatic but I do not remember the gear set numbers.
Top
PostPosted: February 13, 2018, 1:42 pm
Offline
Images: 0
ok thanks guys May just get a proper with nine inch and wheel spacers to replace the modified 76 f100 nine inch currently in the truck
_________________
Top
PostPosted: March 14, 2018, 7:50 am
Offline
I have a 3.73 LS Dana 44 out of my 64 if you want it. I narrowed a 9.75 for a 4 link swap. 50 bucks? Could probably use seals... no rust as it is an AZ truck.
Top
 Profile
PostPosted: April 5, 2018, 12:55 pm
Offline
Images: 0
OK, is it a locker? If so Depending on shipping that sounds fine. I'm in the south west MO. area so It might be easier to just get the carrier assembly. and does anyone know what all is involved with converting these to 19 splines to the cheaper gear sets that are 27 spline? I am wanting to go 3.31 gears until I get a Nv4500.
_________________
Top
Who is online
Users browsing this forum: Bing [Bot] and 4 guests
Search for:
Jump to:
