It is currently February 23, 2018, 6:51 pm.
Post new topic Reply to topic  [ 6 posts ]
Author Message
PostPosted: February 12, 2018, 10:04 pm
Offline
Hey all,
I have been looking at doing a disc brake upgrade on my 63. I have stock steel wheels. The kit I want to use is the Speedwak kit. Does anyone know if I can still run the stock wheels if I upgrade to disc up front?
Top
 Profile
PostPosted: February 12, 2018, 10:55 pm
Offline
Images: 8
I did the upgrade on my '64 and ran stock 15x7 wheels on the front...no problem. The kit is excellent, well worth the price and will make a world of difference in braking. Later went to 17 x8 Dodge Ram wheels and then back to 15 x 8 Wheel Vintiques steelies. All fit over the discs and calipers without any issues.
_________________
Top
 Profile Personal album
PostPosted: February 13, 2018, 9:03 pm
Offline
Images: 26
I don't think 15 x 7 is stock for our trucks.
A 15 x 6 wheel I have, which does work with discs, is 14 1/2" diameter where the caliper would be. That measurement is taken about 1" from where the wheel contacts the hub and remains about the same to the outside of the wheel. Within that 1", it does taper smaller. Compare this to your wheel and you should get some idea.
_________________
Top
PostPosted: February 13, 2018, 9:30 pm
Offline
Images: 8
You are right about the stock wheels... I forgot that the 15x7's came from an early 90's F-150.
_________________
Top
PostPosted: February 14, 2018, 9:46 am
Offline
Images: 70
Wheels may be smaller than 15x6, could be 16x5.5
_________________
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
Top
PostPosted: February 14, 2018, 10:14 am
Offline
Images: 26
In the parts book, it looks like the 15" wheel is 5.5" wide for '64. If you have 16" wheels, then that makes it more likely that it will fit, given the larger diameter. Either way, you can use the dimensions I provided of a wheel that does fit to get a good idea if the ones you have will or not. If they don't, wheels that look correct and do fit are cheap and readily available, new or used. Wheels really are a small issue when it comes to the common disc upgrades.
_________________
Top
Who is online
Users browsing this forum: Baidu [Spider] and 2 guests
Search for:
Jump to:
