It is currently April 20, 2018, 12:59 pm.
Post new topic Reply to topic  [ 4 posts ]
Author Message
PostPosted: February 20, 2018, 1:51 pm
Offline
Images: 0
Hey guys, I picked up the front axle, rear end and front and rear springs from a nice '61 f100. I'm wanting to get prothayne bushings all the way around the truck and I'm only finding a kit for the back. anyone know if they can be had for the front? Also has anyone here tried some of their 61-64 truck? and whats the best type of anti squeak liners these days?
As always thanks in advanced
_________________
19mpg hwy, .040/298ci, arnd 8.7:1, ECG heads, stainless valves, ceramic coated ramshorn manifolds, B code int., eddy 4bbl, Durasprk II/C5ZF dizzy, C2AE rods,high ratio rockers, NOS two groove h.balancer, unkwn cam-for now :twisted: soon:pwr asst steering
Top
 Profile Personal album
PostPosted: February 20, 2018, 2:34 pm
Offline
Images: 103
I haven't seen a kit, but you could probably piecemeal them together individually from one of the companies that makes them. You can buy the front end rubber sleeve bushings fairly cheap if you look around online. The 61 springs you have may have the small eye in the back. I was tempted to cut down a set of rear spring bushings and fit them in my 61 springs, so that the only rubber sleeve bushings would be in the top of the front shackle.
_________________
My '63 short wrongbed
"The Iron Rhino"
-300-6 choke tube repair
-duraspark II/ HEI
-turn signal indicator fix
Top
PostPosted: February 20, 2018, 5:08 pm
Offline
Images: 27
Prothane and Energy Suspension have universal products. You just have to measure and see if they have a part that will work.
I have not used any on my truck but I am skeptical of using them because polyurethane bushings are really more like a bearing, which needs lubrication. The stock rubber bushings flex to allow suspension movement but the polyurethane bushings do not. They actually have to allow the metal inner sleeve to slide and rotate within the bushings. The problem is that the initial application of grease does not last that long and that causes the suspension to kinda stiffen up and not function as smoothly. If there is no way to grease the bushing after the initial installation, then you're stuck with that. I would only consider polyurethane if they were easily greasable or the probably made in China replacement rubber bushings simply do not last.
I do have polyurethane on my car so I'm not coming from absolute inexperience here but it is all greasable. using a grease gun. I grease them 2 - 3 times a year and I do notice a difference afterwards and the ride getting rougher if I go for a longer period without greasing.
_________________
Lawrenceville, Ga
1961 F100 Unibody
Top
PostPosted: February 21, 2018, 5:57 pm
Offline
Images: 18
National Flag: Canada
Here's a good source for universal bushings from Prothane. They also list a cross reference to the equivalent Energy Suspension bushing for each size, if available:
http://www.prothanesuspensionparts.com/universal-pivot-bushings.asp
I don't have specific experience using them in a leaf spring bushing application, but I had good luck using ES bushings on my old car without any ill effects. I didn't bother with the little packet of grease they supply with the kits though. I gave everything a liberal coating of this during the install instead:
https://www.amsoil.com/lit/databulletins/g1281.pdf
That lasted a few years (until I sold the car) without any noticeable squeaking, but I would still expect to have to tear down the bushings once in a while to reapply the grease. The shackle end would see more relative motion I would think, so subsequently would likely need attention first.
_________________
Excrutiatingly/Ridiculously/Obscenely Slow Build Thread
Canadian-Built Ford & Mercury Truck Data: VIN Decoding
Top
Who is online
Users browsing this forum: No registered users and 4 guests
Search for:
Jump to:
