Cab sag
Cab sag
I had not remembered this problem, and I should have, I know it well. The same problem causes all kinds of other issues and for the same reason. Cab will not stay in the right orientation and moves around, not only will this cause problems with the steering column but clutch linkage as well, and linkage will not stay adjusted well.
Re: Cab sag
Yep, on my Unibody I have to adjust the front cab mounts at least twice a year.
Robert
Robert
- 6166 Junkyard Dog
Re: Cab sag
Rich for many years we talked about the problems of what happens with bad cab mounts,, even some of the big companies have listened to me telling their customers what to look for since they claimed never heard of such a thing but yet they claim to be top truck dealers,, Anyway what happens when cab mounts go bad the cab drops down with the only thing holding the cab up is the gear box putting pressure on the steering column as well in which affects the shifting, staying in park, steering hard, tearing up the column at the bottom and even wearing the shaft so thin that will break given any time without doing something about it or even shearing the bolts off the gear box. It has been posted on our website on these problems for years as well. I have seen 2x4's holding up cabs but the best was as set of forks off a fork lift holing up the cab also. When it comes to manual trans it affects shifting and anything to do with the clutch as well
Now Cooper will try his best
