clutch equalizer bar
is there a difference in the v8 and straight 6 equalizer bar.
1961 F350 pick up
1962
1963
1964
1965
1966 F350 camper
1962
1963
1964
1965
1966 F350 camper
Re: clutch equalizer bar
The truck I'm working on is a 4x4 with a mid 70's 4x4 frame.
The truck had either 352 or 360 V8 and I swapped in a 300 straight six.
I used the same z-bar that was with the V8 when installing the 300.
The ball that screws into the block was already in the 300 and I've sold the V8 so I don't know if they are the same.
well as long as you used the same bar from the v8 on the 6 and it worked ok you answered my question. I did the same thing. 8 out 6 in but clutch seemed to be engaged or disengaged no in between. thought might be the equalizer bar had a different throw than a 6.
1961 F350 pick up
1962
1963
1964
1965
1966 F350 camper
1962
1963
1964
1965
1966 F350 camper
