how can i hop up a 352
reeses66ford
Post by reeses66ford »
my old truck has a 352 what parts can i use to hop it up? someone said a 360 or a 390 parts will work in it?
mikecarson
Post by mikecarson »
Mike C
64 CC, Crown Vic project
62 CC
67short 94 F150, 433W
jkimbrel65
Post by jkimbrel65 »
Please :D a little more info.What do you mean by hop up? Means different things to different people.
1. aluminum 4-bbl intake
2.4bl carb 600 cfm is good
3.headers and free flowing mufflers
4 update ignition system mid 70s duraspark II works well
5.bigger cam
and there are lots more but they get $$ Hope this helps
Mike
I tried being normal once...
shane amigoni
Post by shane amigoni »
where did you find a cam? i cant find heads either. Should i keep the 352 or swap it with the 1970 302 i have which i have found much more performance parts for?
reeses66ford
im going to keep my 352 i would like to put a small cam but has a little kick and headers,4 bl intake alm, valve covers and a msn ignition on it.
reese
Uncle Skip
FE motors
Post by Uncle Skip »
352 heads are fine, but have hardened valve seats put in when you do the valve job. When you look for a cam, go to someone like Jegs and get a 390 RV style cam and keep it under 285 degrees with a max of 1/2" lift.
Headers are a must, but they have to be specifically for a Ford truck. Car headers will not work.
Also, find a set of adjustable rocker arms and hardened pushrods.
I'd recommend a 390 if you can get one cheap (and you should still be able to find them) because the stroke is longer and for some reason, it gets better gas milage than the 352/360.
Makes more horse pressure too.
U@ss
BigTim
Re: FE motors
Post by BigTim »
Uncle Skip wrote:I'd recommend a 390 if you can get one cheap (and you should still be able to find them) because the stroke is longer and for some reason, it gets better gas milage than the 352/360.
U@ss
I agree.
unforgiven66
Post by unforgiven66 »
If you are interested I have lots of 390,390GT,427's and 428's.Many new and some used parts.Let me know what all you want.
DV65CustomCab
Post by DV65CustomCab »
reeses66ford wrote:im going to keep my 352 i would like to put a small cam but has a little kick and headers,4 bl intake alm, valve covers and a msn ignition on it.
The key to the FE is realizing it is not a high rpm revver, but a torque motor. Low rpm power is what you need to persue.
"RV" cam, yes.
Headers...well, they will flow better than manifolds, but many feel they are leaky, obtrusive PITA's. :?
Aluminum intake will save weight and will probably flow better than the stocker, but I wouldn't say it's a necessity to do that and a 4 barrel.
4bbl carb, don't make the mistake of going to big like most people. The carb should be sized to work with your cam and heads. Bigger isn't always better.
MSD ignition, probably unnecessary expense. Pertronix makes a drop in replacement electronic ignition that is far cheaper and reliable. I'd save the MSD for the race engine guys.
Stop The Longbed Hate! :)
Now: '93 F150 Lightning
Comet
Post by Comet »
unforgiven66 wrote:If you are interested I have lots of 390,390GT,427's and 428's.Many new and some used parts.Let me know what all you want.
Hmmmmm, yummmy. Look away, Comet...look away! :lol:
mcarlson11
Post by mcarlson11 »
im looking for a complete 390 that runs.
65 F250 Custom cab, camper special. 352,4spd floor shift, dana 60 posi lock, power disc brakes in front, power steering, and fun to drive.
64 f100
Post by 64 f100 »
I somewhat disagree with the mileage statement. However, there's not much difference. I think the 352 could get significantly better mileage with an improvement in compression. The later 360 was very low on compression. If you can find some of the rare COAZ heads with a very small head chamber, this would help. There are plenty of heads out there for the FE's but most have about the same combustion chamber size. Not sure, but believe some of the 352 car engines were equiped with better compression ratio's. The main problem with 352, are related to pistons, and rings. These cost more, than for the 390, and are harder to find. Adjustable rockers are a hard part to find, or just plain expensive. I know of several 390's here in southern Illinois. If your close, I can help you find one. Evilbay has several listed usually. I noticed one in the St. Louis Sunday paper.
1961 F350
1964 Galaxie convertable
1965 Ranger, and shortbed
1966 long bed, and shortbed
A few parts trucks also
1991 Capri
2011 F250
2004 Lexus
jeepbut
Post by jeepbut »
Give the 352 two joints and a black molly. Thanks, Lyman.
Bills 66
Post by Bills 66 »
If your 352 is still in good condition. There are some easy mods to wake it up. Headers are a must. Install a streetmaster intake and 650 carb and a comp cams 262 cam and new lifters. The differance is very noticable. Ask the iceman how his wifes 4x4 runs.
The good part is if you decide later to go with a 390 or 428 all the parts will swap over.
reeses66ford
RUNS LIKE A DREAM! LOW MILES THE OLD MAN GOT HER NEW HIS SON HAD IT IN HIS BACK YARD I STOPED AND BEGGED HIM TO SALE HER TO ME HE SAID NO SO STOPED BACK 3 MONTHS LATER HE SAID NO, THEN HE CAME TO MY HOUSE AND TOLD ME TO GIVE HIM 300.00 AND THATS HOW I GOT SHORTY THE TRUCK.
reese
