Cigar lighter
j-mac
Cigar lighter
Post by j-mac »
Alright, another stupid question from me:
What do I need to hook up the cigar lighter in my 62?
The lighter socket is there, but no wire hooked up to it. I have a whole mess of wiring underneath my dash (PO did all kinds of wacky wiring all over the truck). I do have one wire that I've tested to be working... I'm not super familiar with wiring still - but it doesn't seem like it should be that difficult to do.
The lighter itself didn't actually come with the truck, so the socket may not even work. I really just want it to plug an ipod into for some tunes in the old girl.
Comet
Post by Comet »
If memory serves, the housing acts as the ground, so just a hot wire to the terminal and go. You can use a keyed on, or constant hot. I prefer constant hot in case you plug something in the lighter for power, the key doesn't need to be on.
My Slick is rustier than your Slick! :D
j-mac
Post by j-mac »
I didn't even think about keyed vs. constant hot, but that makes sense - thank you muchly Comet.
Forgive me for my ignorance but I've just never done this stuff before. Do I just attach the wire to a ring terminal, and then stick that on the back of the lighter housing?
My knowledge is starting from scratch here! :oops:
Comet
Post by Comet »
Yep, I think that's all it takes! Mine works that way anyway. But I have an aftermarket housing from Schuck's or something and use a re-popped element from Mac's Ford. But I'm pretty sure the originals worked the same way. Just make sure you have good contact with the metal dash for a ground.
Comet
Post by Comet »
Oh, and you don't need to apologize, everyone starts somewhere. Funny, when I posted originally, I didn't notice who asked the question! I know you! :D
jakdad
Post by jakdad »
j-mac wrote:I didn't even think about keyed vs. constant hot, but that makes sense - thank you muchly Comet.
I would check it with a jumper wire first.
Jim
Fanatic
Post by Fanatic »
Jim,
the ring terminal idea may work but it will be REAL close to touching the housing and shorting out. You can bend the terminal or , as the factory did, use an end like is on your coil with the elbow that just pops onto the stud ---plus its protected.
Tim
no question is a dumb question!
