rear end question?
rear end question?
i have a 63 ford f1oo. it is a 223 4spd. the main bearing and/or shaft is going bad and making some noise. i have a good 302 and auto trani i was thinking of putting in it. it has a 9inch rear with 3.89 gears someone told me that the old rear ends would not hold up to very much horsepower. i was wondering if someone could tell me if that is true and if so what year i would need to switch to. thank you
if its basically a stock 302, that 9 inch well easily handle it.
i had a 302 in a 61 uni and never had any trouble.
they are a nice compact good amount of hp engine.
good luck with that swap 8)
Re: rear end question?/ trani opinion
bab85 wrote:i have a 63 ford f1oo. it is a 223 4spd. the main bearing and/or shaft is going bad and making some noise. i have a good 302 and auto trani i was thinking of putting in it. it has a 9inch rear with 3.89 gears someone told me that the old rear ends would not hold up to very much horsepower. i was wondering if someone could tell me if that is true and if so what year i would need to switch to. thank you
does anyone have an opinion an what they think is cooler and more practical, should i find another 4spd or go with the auto, i want to actually drive and use the truck a little. would anyone know where i could get a good 4spd at?
http://www.4speedtoploaders.com/
If you plan to drive it alot you might consider a M5OD from a 90s F 150 (make sure the shifter seal is good though), or a Mustang T-5 with a tailshaft housing form a S-10 T-5 (moves the shifter to the right place for our trucks). An AOD automatic isn't bad either, just get one from a 5.0 Mustang or from behind a 5.8, they have more clutches.
Unless you already have a 5.0 get one of those from a Mustang also, they have a roller cam and the HO heads so the torque is better for heavier vehicles, another option is a 5.0 from an Explorer, roller cam engine also with GT-40 heads. The extra torque will give you better efficiency because the engine won't work as hard to move the truck. The headers on these engines should also work in your slick.
the 3.89 is a wicked rear end with a V8. I put a 390 in front of mine, and it scorched the tires easy, and chirped rubber when it hit second.
THe 9 inches are seriously the best thing ever created. I just wish mine was a posi trac/locker
I wonder what your buddy thought you should get??? A C#@^Y 10 bolt?? ha probably. lots of idiots like them! and they'll blow chunks easy!
- Johnny Canuck
bab85 wrote:someone told me that the old rear ends would not hold up to very much horsepower.
You were obviously talking to some goofy cheXXy numbskull.
9" FORD rear end is the drag racer's choice by 15 country miles.
One of the funniest thing I ever saw was, at the hundred footer drags they have here every July, some twit in a belly button Nova's rear end go kaflooey when the lights turned. I damn near peed meself ...and so did he.
61ford wrote:hes probably talking bout how the pre 65 9 inch rear tended to snap where the axle tubes were butt welded to the pumpkin housing.
so it sounds like a little reinforcement might be an order? I think I may do that before I add any more power to aggie!!!
