pictures 64 tri power 100 +390 powered chev coupe
posted some pictures joeymac64 of my 64 390 tri power 4 speed truck and also of my 34 chev on 34 ford frame mustang 2 front end and 390 installed will be taking engine out of truck to put in car and putting an 87 ho 302 5 speed into truck only good thing about winter is your forced to stop driving and make your changes to your rides
- Johnny Canuck
looks like a great project, though myself if i had a tri-power 390 in my truck that ran and looked that good i am not sure i would want to go thru all the work of swaping it for a 302.either way though still very nice.
i noticed in the 64s engine compartment on the firewall the hydraulic clutch mc.is this a Canadian or Mercury thing or did you install it yourself for a particular reason?
what you are saying is instead of the hydraulic pressure being used to move the linkage,instead you bypass that and the fluid operates the bearing?
i would like to see a pic of that.throwout bearings and the rods and arm are a pain to mess with in the cold and the grease is cold too so the bearing might not spin right....never cared for the ford hydraulic clutch bit this sounds like a better deal.
iceman you nailed it right on the head my truck is a 64 with 66 i beam installed to much agrivation to try and make linkages work this bearing is made specicically for the ford toploader and works amazing my 5 year old can push the clutch in and out centerforce II clutch and pressure plate i just ordered a 3rd generation camaro hydralic bearing off e bay as it looks simalir to the mcloud bearing to see if i can make this work mcloud bearing is just under 400.00 camaro bearing 55.00 off e bay i'll let you guys know how i make out these bearings make easy swaps into any vehicle
