It is currently February 25, 2018, 6:48 am.
Post new topic Reply to topic  [ 4 posts ]
Author Message
PostPosted: July 11, 2017, 8:10 am
Offline
I have a 1963 Swb F100 for sale. This truck is not assembled at this time. I do have a clear title on the truck and it is being build as custom not back to stock. I will list everything I can think of below and if you have any questions please ask parts as follows:
•Cab (1965 cab) new floor pans, fully shaved, door actuators installed 7 months in the body shop no radio hole in dash. This thing is STRAIGHT and rust free new cab corners, door skins and over 100 hours of block sanding alone
•Front fenders super clean, primered ready for paint (no damage/rust)
•Hood ready for paint in primer (all trim shaved)
•Grille 1963 the grille has been shaved of marker lights and primered
• headlamp buckets and bezels
• frame mount gas tank and sender
•Upper panel shaved and primed
•Core support is brand new aftermarket with correct mounting brackets installed
•Inner fenders primed (don't love them but useable)
•Hood hinges
•Short bed from 65 model style side not step (has not been body worked CLEAN sides inside bed needs work)
•Frame 1965 model stock rails with 04 p71 vic front installed. Have brand new complete struts, drilled/slotted rotors and tie rods/bushings for it frame has not been boxed or painted yet
• engine 99 5.0 explorer complete with harness and Ron Francis programmed computer
• trans 99 4r70w fully rebuilt BRAND NEW by Cantrell racing transmissions. Controls from PCM
• 8.8 explorer rear axle 3.73L with discs (new drilled slotted rotors, calipers, hoses)
• aluminum 3core radiator with fans
• full 21 circuit harness
• hood hinges
• tailgate
• chrome tilt/ automatic column
• new key cylinder/keys for ignition
•Aluminum dash insert 6 hole
• new after market 6 gauge set
• led headlights
• windshield rubber, door seals
• I have a set of Ford Edge seats (black leather)
• lots of odds and ends
What I know I don't yet have:
• bumpers (I was planning roll pans)
• shocks for rear end
• windshield
• cab mount bushings
Extra parts:
• front fenders, core support and hood
• lots of various small parts etc
This has been a labor of love and a long project. I unfortunately am in a position that I must now sell this. I have several pictures if you are a serious buyer for this truck with clear Oklahoma title in hand. This will have to be trailered it is NOT assembled or road worthy at this time. $5000.00
Top
 Profile
PostPosted: July 11, 2017, 12:25 pm
Offline
Images: 1
Is the '65 cab' from a 4-wheel drive truck? I only ask because the two wheel drive frame and cab mounts etc changed between 64-65.
It may help if you add some info to clarify which you have and how/if they will work together.
_________________
Top
 Profile Personal album
PostPosted: July 11, 2017, 9:44 pm
Offline
1965 frame. Thank you for asking
Top
 Profile
PostPosted: July 27, 2017, 11:56 am
Offline
Images: 1
I guess i'm still confused - the ad lists it as a '63. But if the frame and cab are '65, isn't it a '65?
Also i see reference to an OK title but I didn't see where the truck is located (maybe I missed it?)
_________________
Top
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
