Which rearend for CV swap on 62 uni
Hello fellas, I recently installed ifs from cv on my dads 62 uni,now my question is which rearend can i bolt on to get the 5x4.5 lug pattern? I will be using 05+ mustang rims as they are easy to come by.Thanks
Re: Which rearend for CV swap on 62 uni
if your are keeping rear drum brakes you can have a shop take studs out ,weld it up and redrill to your specs. If it has a ford 9" you can redrill or you can buy new axles with correct bolt pattern... just a fyi if your going to redrill go ahead and buy new drums no reason to pay to redrill old used drums that will be shot in no time
Danny
Danny
Is the 9" in it rite now same width as the front? we are trying to get as close as possible width as the front.Thanks
I think the 9" is a little narrower than the CV front end , you can use spacers in the back or order correct offset for wheels to even the track width. I don't know of another rear end that will swap into truck that's correct pattern and track width, sorry.
Danny
Danny
Things I have learned on my swap in progress...
03+ Crown Vic is way to wide....
I put my 9 inch back in and used 2 inch adapters that gave me a width of 65" Hub face to Hub face.
I also found out an axle flip lowering drops the back like 6 inches
