406 fe big block
therealjoeshmoe
406 fe big block
Post by therealjoeshmoe »
anyone know anything about a 406 fe big block??
is it worth a crap or just a good boat anchor? lol
Image Image Image Image
LM14
Re: 406 fe big block
Post by LM14 »
The 406 was an original race motor in about '61-62. It should have the hipo heads with bigger valves but it would also have the early motor mount bolt pattern and solid lifters if I remember correctly. It was replaced by the 427 in '63.
Bore is the same as a 428 but the stroke is the same as a 390. Kind of backwards from a 410. It should be a cross bolt block if it was a later block, earlier ones were not always cross bolted.
If you can get one, get it. They bring some fairly big money.
6166 Junkyard Dog
Post by 6166 Junkyard Dog »
AS a rule that I was reading a long time ago when I first built my 427,, 406's where not cross-bolted, UNTIL they started coming apart and a kit was offered to change that over to that until the 427's came out and ALL 427's are cross-bolted, IF somebody says it's a 427 and not cross-bolted then they are telling you a lot of :bs: 427's where offered until 1968 and the 68 motors where hyd. lifters,, my 427 is serial # from Ford
12649
therealjoeshmoe
IM GONNA GET THE NUMBERS TONIGHT AND TRY AN FIND OUT IF I HAVE A 406 NOT SURE WHAT I HAVE REALLY
LM14
Post by LM14 »
You are 100% correct as usual, Tom. The only cross bolted 406 were the end of the run until the 427 came out. They are very rare.
Joe, if it is indeed a 406, there are some collectors that will pay (in my opinion) way more than they are worth. The Galaxie guys drool over them. There is a guy in the Omaha area that buys a lot of them.
therealjoeshmoe
well i dont think its a 406, (would have been real nice to have one) After some research online im thinking its a 63 352 but im gonna take the heads off and measure the bore and stroke after im done freeing up another 352 i got on the stand... it does have the earlier offset motor mounts
heres some pics
Uncle Skip
Post by Uncle Skip »
Joey.
If you decide that isn't a 406, let me know and I'll come get it.
Uncle Skip
Uncle Skip
Seriously, the casting number on the block C3AE-6013-Z is for a 427 top oiler. What is the casting number on the heads. Those are not 427 exhaust manifolds, or 406's either.
Strange days indeed.http://www.fordification.com/tech/castingnumbers-FEblock.htm
therealjoeshmoe
I THINK IT SAYS C3AE-6015-E IM PRETTY SURE ITS A 63 352
Pack Rat
Post by Pack Rat »
is it drilled for oil galleys for the lifters?
http://www.jalopyjournal.com/forum/thre ... 06.639669/
And I will buy a boat to use it as an anchor if you dont want it. :lol:
1966 F100 240 3speed
1968 F250 Camper Special 390 C6 with 70 Sells slide in camper
1964 Galaxie hard top. 390 dual quads
1962 Falcon soon to have 428 4 speed and straight axle.
6166 Junkyard Dog
IF somebody says it's a 427 and not cross-bolted then they are telling you a lie which in this case it's not a 427 since I do not see the cross bolts right above the oil pan
12649
therealjoeshmoe
i figured that i knew it didnt have the cross bolts.. i figure its a 352 or 390 at this point i dont care what it is lol but its mine... and its an fe, prolly a future rat rod project... riot.gif
