I need help growing my Bell Peppers
tomrooster
Post by tomrooster »
What is causing this to happen, no bugs inside, happens every year, not to all the peppers just some. Thanks Tom
1966 F 100 w/391 ft
1965 F 100 project
1958 Edsel Pacer Convertible
1953 ford Customline 2 door
1952 8N
1967 triumph Bonneville
Re: I need help growing my Bell Peppers
I've seen that on mine
Didn't plant any this year though...
I think it's a worm
Have you tried putting sevin dust on them ?
jamesdfo
Post by jamesdfo »
Tom: Next time you go hunting peppers, I suggest a .22 , as you can see, the .308's leave too big a hole :):)
But seriously folks.....I think Slick4x4 may be on to something with the worms?
I guess I was fortunate, the one year when I planted peppers, they all came out really well, even the little ones that were so hot they made my lips glow:)
James
RustNdust65
Post by RustNdust65 »
Calcium deficiency...aka end blossom rot.
Take some egg shells and crush them up and mix it into the soil around your peppers.
tomrooster
Thanks Rust
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
robertrpeak
Post by robertrpeak »
I have what appears to be the same on my tomatoes, I put it down to the heat we are having this summer, my okra is only 4" tall right now, should be near 4 foot tall!!!
Robert
RustNdust65
It's caused by to high of nitrogen levels in your soil which happens naturally over the years especially if you grow in the same spot. Next spring I recommend adding lime to the top 12 inches of soil and you should be good for a few more seasons. I use crushed egg shells for my tomatoes and peppers and it seems to work
orangeRcode
Post by orangeRcode »
RustNdust65 wrote:It's caused by to high of nitrogen levels in your soil which happens naturally over the years especially if you grow in the same spot. Next spring I recommend adding lime to the top 12 inches of soil and you should be good for a few more seasons. I use crushed egg shells for my tomatoes and peppers and it seems to work
I do the same thing. The wife thought I was crazy but has seem to have solved the issue with the tomatoes. Never had that with the peppers but figured it couldn't hurt.
longcabjohn
Post by longcabjohn »
Might help if you shoot the rabbit.
Johnny
tomrooster
I put plenty of lime in the fall and spring, the pelletized type, this year I moved the area for the peppers to a new spot that never had them before and 2 nights ago the deer trimed 4 tomato plants for me, we don't eat enough eggs so I'll try adding some calcium next year. Thanks. Tom
1966 F 100 w/391 ft
1965 F 100 project
1952 8N
