T5 speedo question
64 f100
T5 speedo question
Post by 64 f100 »
Since this is the first one of these I have installed in one of these trucks, I need to ask if the speedometer cable will work with the stock end that came out of the original 3 speed transmission. I'm using the stock tail shaft housing that came with the T5 and not doing the T-10 tail shaft conversion.
charliemccraney
Re: T5 speedo question
Post by charliemccraney »
It worked for mine but the gear in the transmission must have a different tooth count because the speedo indicated differently at the same rpm in 4th (same as 3rd of the 3 speed). So, you may need a different gear on the end of the cable to correct that.
unibody madness
Post by unibody madness »
Charlie,Did you change the internal,larger drive gear, or where you able to adjust with the smaller gear? do you remember which colors? Right now I am using my TomTom as a speedo.
64 f100
Post by 64 f100 »
charliemccraney wrote:It worked for mine but the gear in the transmission must have a different tooth count because the speedo indicated differently at the same rpm in 4th (same as 3rd of the 3 speed). So, you may need a different gear on the end of the cable to correct that.
Thank you for responding.
charliemccraney
I didn't need to change anything. I took a GPS with me and it was dead on, so the small gear I had been using was wrong for the 3 speed.
