When did that clock start ?
Says 293 days till......
First I noticed it :shock:
6166 Junkyard Dog
Re: When did that clock start ?
Post by 6166 Junkyard Dog »
I see it Pat as well,, will not be long till it's down to the final hours,, OK Guys/Gals get your winter projects started
12649
I’m WAY ahead! Started on my winter project 63 months ago!
Let's see, roof replaced, both cab corners (inside and out) replaced, both floor pans replaced. Need to replace cab mounts, left cab cross member, rust repair on two doors, rebuild rear end, block sand entire truck, paint truck inside and out (not sure what color(s), rewire truck, and all the misc. stuff. Heck I'm almost done!!! :roll:
The one in the shop now is the truck I would
Like to drive to KC in 2018....
It's in a lot of pieces :oops:
But I figured if I don't spend anytime on bodywork
Or paint .......
Save me a lot of time ! :mrgreen:
Good tires , good brakes , dependable drive train ....
Oh yea AIR CONDITIONING !
we been pretty lucky with cool weather at SlickStocks
But I'm predicting a hot one next year
orangeRcode
Post by orangeRcode »
slick4x4 wrote:The one in the shop now is the truck I would
Or paint .......
Bite your tongue. No AC for me.
LM14
Post by LM14 »
I have been cleaning my shop every day for the last 2 weeks! Hard core cleaning, throwing stuff away, hauling off scrap and blowing dust off everything. I have found the floor AND the tops of 4 work benches! Amazing.
I can now touch all sides of my unibody without having to reach over other stuff. Time to get back on it this winter. Let's see.....finish welding in the Industrial Chassis Dakota kit, fabricate and install the rest of the rear 4 bar, finish the engine mounts, rebuild the engine and tranny, big back window section to install, finish fabrication on the steering, make the exhaust, get basic body work done, plumb and wire everything.......cutting it close! Might make it if I don't paint anything and the engine build goes smoothly.
Can't wait to see everyone driving in with their freshly completed projects.
:hm: I wonder if Qantas will have a new plane by then, I hope they know the clock is up and running :) surely they do !
I always cringe when I see the countdown clock appear.
Guess I don’t like knowing something is timing me! Got to get
busy and get that work done on my truck! Engine refresh,
new gas tank install, Trans seals, hood swap, and some painting.
Lots to do! TR
Truckrat wrote:I always cringe when I see the countdown clock appear.
Lots to do! TR
Well that's todays work..... What are you going to be doing on it tomorrow Gazza ? :P
