Best way to remove rusty bolts/studs
After reading the exhaust leak thread I thought about the best way to get rusty nuts & bolts off. Heat the nut or bolt to red hot then cool it with a candle. The wax will wick into the threads to help it come apart.
Tom Williams
- ezernut9mm
that sound like a great idea. i have no shortage of candles. i guess now all i need is a torch rig. boy, i could do a lot of damage with one. i really, really want one too.
ezernut9mm wrote:that sound like a great idea. i have no shortage of candles. i guess now all i need is a torch rig. boy, i could do a lot of damage with one. i really, really want one too.
i like my torch but really impressed with the plasma cutters.
the wax thing is good, works on brake bleeders too,but be careful where you heat or you will cook the rubber in the wheel cylinder.
How would you suggest getting out the body bolts that go into the clips? I feel like the clips break loose before the bolt does and they just spin in place? We used a grinder on some, a set of needle nose on others, but we are at a loss for the clips that hold the front fascia taht goes behind the bumper on my '66. The spinning clips are inside of a boxed in frame...
- olliesshop
I had the same problem. I ended up using my Sawsall to cut them off, by slipping the blade in between the grille and the stone guard. Which is part of the reason (along with the significant rust) I'll need to get a new Radiator support.
Tim - 1961 F250 Uni
