well the old truck aint had the oil changed in ...at least since clinton was in office, for the first time. and well i guess the oil filter didnt want to leave..so i ended up tearing it all to heck and every thing i put on it tore it up worse but i found a trick in the process
if you get one that is really bad take all the metal off and the guts of the filter. so you only have the base left, the part that touches the block you will see the screw that comes out of the block and the little holes all around it, what i did was found an allen wrench that fit in the hole and a bolt that fit. then put the allen in a hole and the screw in another hole and pushed down on the allen with a small cheater bar and..it broke loose with minimal cursing. but be carefull that thin metal will do a better job than the red cross at takin blood.hope this helps, it did me so i thought i would share.
stuck oil filter removal
No, its not a windsor or a cleveland, its a three fifty TWO!
