Steering wheel repair on a budget.
OK, so I know there are a few neigh sayers out there that will probably roll their eyes at this and say "leave it to the pro's" but, on a budget this is the best way I've devised for a decent repair for you old ford steering wheel. Granted, this is the way I do it, and I can't be held responsible for damage to your wheel. Beware and do this only if you feel your level of experience will allow you.
Here is the offending beast, a 45 year old, nasty cracked wheel:
The first step is to remove the wheel making sure to unscrew the horn contact on the back. Next you clean the wheel thoroughly. And I do mean thoroughly! You need to make sure that the areas inside the cracks get clean as well. I've fount that good old fashioned lacquer thinner works well.
Next take a triangular file and grove each and every crack. Mix yourself up some JB Weld. I know, I know but, I've tried everything and JB Weld (not the quick stuff) holds up really well and is easy to work. I use it for everything, even wood working. It's hard and like I said easy to shape.
You'll probably have to buy a couple of packages depending on how badly your wheel is cracked.
When you're done your wheel will look like this:
Now, walk away and leave it set over night.
The next day, start with a flat file for the outside and a half-round for the inside and roughly shape the filler but not too much. Now the fun part. Clear your schedule and plan on a few thumb blisters. Sand every nook and cranny until you get the desired shape. This isn't like bondo work where you leave a little filler in place to hide the dent. No, you have to sand away all the filler except for what's in the cracks. Start with course (80 grit) and work your way up to extra fine (400 grit) until the wheels shape is once again smooth. Remember, if you can feel it, you'll be able to see it once it's painted.
Now, for the paint. Here is the sanded, painted wheel:
On other forums there is much talk about the proper paint used to paint the wheel. Personally, I use duplicolor truck and van lacquer. It leaves a beautiful shine and is durable. Sure, maybe not as durable as an epoxy based paint but hell, I don't mind pulling this thing back off down the road and fixing it. Use what ever paint you want. I use the duplicolor because I can get it in a color that is complementary to the trucks interior. Granted, duplicolor doens't make "Marlin Blue".
Let it harden, as painters we are inevitably impatient. Give it a few hours in the sun to cure a bit. Lay a clean towel on your bench and lay the wheel face down and replace the horn contact ring. Then put the wheel back in and ta-da, 45 years of wear have magically disappeared. I figure after 40 some years the wheel has shrunk as much as it will in my lifetime so cracks down the road shouldn't be a problem.
Is it as nice as one of those $400 professional repairs? Probably not, but the untrained eye would have a problem pointing it out.
I did my wheel too. I used 2 part epoxy and had to make a round clamp sort of jig to hold the center hub in place due to mine being cracked all the way through and spreading in 2 places. I wrapped tape around where I was going to squeeze in the epoxy. After it dried I just sanded through the tape into the epoxy. Like you said sand till it hurts but do not sand away contours. The hardest is the ribs in the center and spokes but the triangle file and a nail file makes good ribs.
And it is a lot cheaper and mentally fulfilling than paying for someone else to do it or buying a NOS one.
You have saved enough doing it yourself you can take the silicone out of the vent window and buy new rubber weatherstripping. LOL
1966 Ford F-100 LWB 300
JB Weld should be an excellent repair filler for this. I would guess the 2 part filler in the restoration kits is pretty similar - sure looks to be about the same texture in the pics. That looks great BTW!
- Brians1966
steering wheel
Awesome job ccain,
Also nice lookin slick- have the same issues with my 66, I see a new lookin wheel in the near future- Thanks for the help and info
Brian
Brian
1966 F-100 LONG BED, 240cid 3 speed red and white, Red and White Interior with a Mossy Oak Seat Cover
2013 Ford F150 STX Supercab 5.0 litre
DETERMINATION: The feeling you get right before you try to do something incredibly stupid!
CONFIDENCE: Is the feeling you have before you fully understand the situation!
- Okla66F100
- slickmainer
its been covered but I just ordered some of this NuMetal Putty. Im going to follow the video. looks pretty good.
pt1
http://www.youtube.com/watch?v=wIEM7r_B ... ure=search
pt2
http://www.youtube.com/watch?v=1EzPmNyo ... re=related
pt1
pt2
--Gregg--
you can't get there from here
steering wheel that makes your had black
I have a 66 F-250 High boy with a steering wheel that is solid but when I drive it it makes my hands black. Can I do the same as you had done by painting it? Thanks
Oldman
- slickmainer
steering wheel
Thank you for the information. This will be a good winter project. I am looking forward to it.
Oldman
