thin wall steel bushings
when i need to repair a slightly worn linkage shaft, anchor bolt or pivot point i use a steped steel golf shaft. it has OD's from 5/16" to just under 5/8" in length's from 1" to 2" in some sizes. stiffer flexes will have more wall thickness.
"I haven't failed, I found 10,000 ways that don't work" Ben Franklin.
