backspacing and offset question (65 F100)
Posted: May 13, 2017, 12:09 pm
I spent some time this morning searching this forum for an answer but came up short. Most of what I have found relates to back space.
I'm looking to upgrade my wheels on my 65 F100. I need a rear wheel that will extend out to but just behind the fender and look even with the front.
The rear wheels I'm currently looking at are:
9" wide 4.06" backspace and -24mm offset
or
9" wide 4.53" backspace and -12mm offset
(my current rear wheel is 16x 9.5" wide with 4" backspace (I don't know the offset if any)
For the front I currently have a 15"x7 4.5" backspace and 0 offset. I'm going with a 16x8 4.5" bs 0 offset so I know that will work fine. The rear wheel has my mind blown at the moment.
I have no way to try before I buy and I hope to buy, test fit and be happy hence why I stopped here first to hopefully avoid having to return wheels and swap them trial and error style.
Thanks!
or
Thanks!
