In wrapping up the assembly of a customers truck I needed to install new hood springs.
The original hood hinges were powdercoated and then installed onto the cowl. Then to keep them from floping around I put a C-clamp at the forward hinge point to lock it into place.
Then I found a suitable bit of scrap metal I had laying around. This particular piece was a left over from a Model A headlight bar but you could use 1/2" to 3/4" bar stock. I ground the tip into a hook that would catch the end of the anchor pin on the hinge mechanism and bent the bar for better leverage and to help guid the spring home.
[albumimg]663[/albumimg] [albumimg]666[/albumimg]
Pull the lever and use a pair of chanellock pliers to assist the spring over the end of the anchor pin. Much the same as drum brake return springs.
[albumimg]670[/albumimg] [albumimg]673[/albumimg]
And that's it! Simple and safe.
How to install new hood springs without injury
I use a lenght of 3/8" rope and a pipe.
Hook the loop of rope around the front end of the spring and the other end is attached to the pipe.
Stand in front of the truck and pull. It's a bit tough to pull a spring, but you can install it without scratching your painted or coated hinges.
I hate Message Boards.
I did mine a little differently, it worked well and was very safe.
I tied a small piece of rope into about a six inch diameter hoop. I looped this around the spring end. Next I tied a longer rope to a nearby tree and ran the opposite end through the hoop tied to the spring. By pulling on the rope you get a 2 to1 force multiplication that lets you easily extend the spring and pull it over the stud. Cut the short rope and tie it to the main rope to extract it from the pinch point.
Tech
Tech
this is a handy little tidbit of info, as I was once restoring my 78 bronco. I was taking the tailgate apart and little did i know that the tailgate is spring assisted. when i took the spring out it snapped back and "kissed" the back of my hand/ TORE IT OPEN. i bled for quite a while and seeing as i was living at home at the time ( I was 17) dad took me to the hospital and i got 4 stitches. that was the end of the resto mod.
1966 F-100. Family heirloom. (the bale hauler)
2007 can-am outlander 800XT
2007 2500 dodge c/c s/b hemi. (JUNK!!!!)
2003 F-350 8" BDS lift. 6.0L-- BIG & FAST!-- looking for an automatic trans.
jammck66 wrote:this is a handy little tidbit of info, as I was once restoring my 78 bronco. I was taking the tailgate apart and little did i know that the tailgate is spring assisted. when i took the spring out it snapped back and "kissed" the back of my hand/ TORE IT OPEN. i bled for quite a while and seeing as i was living at home at the time ( I was 17) dad took me to the hospital and i got 4 stitches. that was the end of the resto mod.
you quit a project over a cut hand? that's er, determination?
I find a BIIIIIG flat screwdriver to work fine, albeit maybe not as safe as some of your methods.
