It is currently February 19, 2018, 10:43 am.
Post new topic Reply to topic  [ 11 posts ]
Author Message
PostPosted: October 8, 2017, 6:47 am
Offline
I have a set of door panels for a custom cab with the trim. These are fiberglass and are a little dirty but should clean up or run as is in a driver. I'd like to get 250 for the pair and we work out shipping.
I'm having issues attaching a picture so pm me your number and I can txt you a picture.
Top
 Profile
PostPosted: October 17, 2017, 9:24 am
Offline
Bump these are taking up space and need to go
Top
 Profile
PostPosted: October 31, 2017, 2:56 pm
Offline
Nobody interested?
Top
 Profile
PostPosted: November 9, 2017, 8:49 pm
Offline
Maybe a pic or 2 might help.
Top
 Profile
PostPosted: November 9, 2017, 10:50 pm
Offline
Images: 6
National Flag: Canada
At first, I thought you were selling the CC Aluminum Trim & Inserts (which are plastic) that go on the upper part of door around the inner door handle & window crank....like this
.........but then when I saw fiberglass in the description, I realized that it's more likely what you're selling is the zippered pockets & trim that replace the metal access panel on the lower half of the door??
like this
and yah, pics ALWAYS help sell stuff:)
Top
 Profile Personal album
PostPosted: November 10, 2017, 10:00 pm
Offline
Since photo bucket did it's thing I can't upload from there.
I tried to use the attach though the website and it says the board attachment limit has been reached.
They are the panels behind the door handle and window crank. I thought they were fiberglass re pops. Guess they are plastic. They have the factory aluminum trim.
I can txt pics or email. I really want to move these because they are taking up space.
Top
 Profile
PostPosted: November 13, 2017, 10:35 am
Offline
Images: 0
jamesdfo: I'm like you, I didn't know what he was selling either. I do know that FORD at some point in the late 80's-early 90's did discontinue the white plastic door panels, and soon after that, a company down south somewhere started making a fiberglass repro of them.
Over 4-6 years they made and sold a few over 600 pair, because they were the ONLY supplier of them. They had a white gelcoat surface, and a thin layer of fiberglass on the back to make them stiff enough to use. It had to be thin so you could be able to get the aluminum trim back on them.
I saw a set that a guy had at a swap meet in Maggie Valley N.C. last year. They were made well and held up well, but this guy is BIG on NOS parts so when another company finally started making plastic ones again, he bought a set of them, and was wanting to sell his fiberglass ones. The company that made the glass ones, could actually buy the plastic ones from the other company cheaper than what he had in the glass ones, so he just quit making them.
They also made some fiberglass 65-66 radiator supports at that same time, but only sold 3, because it was too early for fiberglass back then. Everybody wanted to hold out and find a good used steel support.
Top
PostPosted: November 13, 2017, 12:02 pm
Offline
Images: 6
Oldsmiley: I was unaware that anyone had re-popped the inserts in fiberglass. One member on here makes them in plastic (Irl), and I may go with those when the funds are available. I already have the trim and a pair of rough inserts....the problem is, I have a crew, so I need FOUR of all this stuff:):) At least now all I need to do is get the inserts, which are easier to obtain than the trim.....
Cheers!
James
Top
PostPosted: November 13, 2017, 8:04 pm
Offline
Images: 0
Jamesdfo: I sure don't envy you. I bet some of that 4 door stuff IS killer to find. Is it 2 tone with the trim or a solid color?
Top
PostPosted: November 13, 2017, 9:17 pm
Offline
Images: 6
The crew was not originally a Custom Cab, but I've picked up enough of the inner door trim pieces to do all four doors (the back door trims will need to be modified, as the doors are shorter), the inserts won't be a problem.
I still need to find FOUR of the inner trim pieces that go above the door openings, along the edge of the headliner........
Mine was a single colour when new (Code J, Rangoon Red), final colour has not been decided YET, but I am considering Rangoon Red/Wimbledon White.....
Top
PostPosted: December 21, 2017, 3:22 pm
Offline
you have pm shocker998md...
_________________
smith and company auto
1600 crump street
richmond va 23223
804 648 8737
07 PINKS WINNER @ VMP
IHRA CHASSIS INSPECTOR
Top
 Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
