It is currently February 17, 2018, 6:12 pm.
Post new topic Reply to topic  [ 2 posts ]
Author Message
 Post subject: Duraspark 2
PostPosted: July 16, 2015, 11:40 am
Offline
I need a Duraspark 2 module,harness,distributor,coil and plug wires to convert a 300 6 cylinder to electronic ignition.
Thank You!
_________________
Top
 Profile
 Post subject: Re: Duraspark 2
PostPosted: August 5, 2016, 10:03 pm
Offline
Hi, I don't know if you are still in need of the parts in your query but here I go. You can wire up a 4 pin GM HEI module and it will do the same job and it can be mounted by the dist. or it could be hidden much easier than a Dll module, like in your cab. You can find more info if you do a Ford HEI module search on the web. You use your Dll dist, wire your module where you want, and most people buy a heat sink from a computer supply store or a Radio Shack or similar store. But please take my advise and do what you want. Good luck!
Top
 Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
