It is currently April 24, 2018, 11:50 pm.
Post new topic Reply to topic  [ 5 posts ]
Author Message
PostPosted: February 15, 2017, 1:23 pm
Offline
I had a small leak in my 64's fuel line so I removed it and ordered a replacement from some catalog. When I received the new line i noticed its for a v8 motor and those lines are run differently. At some point the old original line disappeared so I have no way of copying it. Does anyone have the line from the fuel pump back down the frame, across the cross member, through that hole in the cross member, and back to the tank? it doesnt have to be pretty just in good enough shape that i can copy it. Thanks!
_________________
'64 ford bbw custom cab short styleside bed
'32 ford 5 window body
'28 ford roadster pickup
'04 ford f150 crew cab short bed
Top
 Profile
PostPosted: February 15, 2017, 3:09 pm
Offline
Not sure if this helps or not but when I ran new line on my 56 I just used 3/8" aluminum fuel line and routed it the best possible way. It's not OEM but functional and looks good. Plus it took about 30 minutes to do.
_________________
Top
 Profile
PostPosted: February 15, 2017, 3:10 pm
Offline
Images: 13
National Flag: Portugal
The manual shows it angled from the fuel pump up at a @45* to the front of the valve cover, 90* to the drivers side , and 90* back to the carb the vacuum line goes from the distributor vacuum pod up to and under the fuel line, following the same path back to the carb.
I would put an in line fuel filter at a point just above the pump in an area easily reachable
_________________
Top
 Profile Personal album
PostPosted: February 17, 2017, 12:59 pm
Offline
im in kingman az have good one off 62 uni 223 and 223 and 3 sp trans runs good putting in 390 bwod dont need them they need a good home
Top
 Profile
PostPosted: March 4, 2017, 6:25 pm
Offline
i took line out but havent heard from your friends when i do ill take to them
Top
 Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
cron
