Doc Pepper wrote: Now if I can fix the holes in my headliner from where I kept bouncing around at that speed, ....
Is yours a round speedo, or the sweep CC speedo? When you pass the 100 mark with the sweep speedo, the needle just sorta disappears.
I'd make sure your tires & suspension is up for it first, though.
Come to think of it...you do that enough times & the spring on the needed tweaks & it kinda goes whacko when you reach 100.
66 F100 CC/65 F100 CC/66 F250 CC If it starts to rain, they'll tax the splash.
i had my 65 f350 with 390 and 4.88 rear up to 100 mph a few years back.
it was not shuddering or shaking, and it was steering straight down the road.
i was sure i could see the gas gauge needle slowly moving toward E, and the sound in the cab was like the concorde jet getting ready to take off.
my wifes 66 f 100 4x4 with a beefed up 352 and 3.50 gears hits 80 with no effort and 100mph does not seem to be the top but theres nowhere to go to safely test it. a long ,straight ,flat road is not found anywhere around here.
the most i have had my 66 with 292 up to is 90, but its favorite speed is about 73 mph, cruises along real nice and smooth.
i have done some braking tests too, on the dry pavement and on the gravel road, and i can report the drum brakes work fine, and stop the trucks as they should.
1966 F250 4x4 1964 Rambler Ambassador 990 Rest in peace departed Slick family members Cam Milam Lesley Ferguson Steve Lopes John Sutton
ICEMAN6166 wrote:and the sound in the cab was like the concorde jet getting ready to take off.
I forgot all about that! Mine used to make this waah-waah reverberation sound through the cab at about 110 & increase tempo as I went faster.
Oh & I'll second you on the gas gauge. I swear I could see mine move too, especially full throttle up a long hill.
Hey Doc, Tom here if you go out Ajo Way WB Go past the airport, past the Customs check tower, then turn right make several turns in the dirt roads you will come up to a sign that says Welcome To Ford Heaven,, A A lot of Ford Vehicles from all years if still there we have not been there in a few years but we carried at least 5 trailer loads of truck parts onlt drawback is they use a Dozer to keep the road clear & every time we went in there had to have the front end redone Dozer Tracs are hard on the front end....... Have bought many parts from Wahl Bros. on Ajo Way but now gone due to Tawain Sheet Metal + that road was tore up so long lost a lot of business also
Tom, @ Lazy FORD Ranch Where Ford Trucks Rest in Peace
Dakota,,, RIP will never be the same looking for 61-66 trucks again ,, Kathy Slickstock,,, York, PA Slickstock,,, Kansas City, MO Slickstock,,, Altoona, IOWA Slickstock,,, Salina, KS
Now Cooper will try his best
Cooper now has 2018 Slick Stock,, give him a fair star Slickstock Kansas City, Mo
