I'm back. What with Christmas and other things going on I haven't been able to work on the 66. But, I managed (with my Wife's help) to get the truck into the shop and get the motor mounts finished up. I cut down the Lincoln trans X-member and bolted it to the tranny but, it's just sitting in the frame rails at the moment.
I removed the Lincoln wiring harness just to find is was pretty ratty. So, I searched around and found someone on ebay selling the harnesses for a couple hundred bucks. Cleaned, devoid of unused wires and nicely labeled for splicing into the trucks harness. I got it yesterday and I'll get started on Saturday.
One question:
On setting the trans crossmember, how do I level the engine? I don't want to take the injection stuff off the top. Can I just put a level on top of the manifold or should I find the angle of the rear pinion and match the rear of the tranny to that?
Well, the Wife is calling "dinner" so...
Thanks,
Jeff
Getting back on the 66
Jeff
66 F100
55 Chevy Handyman
32 Ford 3-window coupe
66 F100
55 Chevy Handyman
- Uncle Skip
A friend of mine just bought a 91 Mustang LX with the HO engine.
He's converting to a carb and I told him to save me all the injection stuff.
We'll see how that works out.
I've been removing some of the stuff from the engine.
Smog pump, A/C compressor etc.
Not much to report thus far.
Can I use the Lincoln power steering pump with a box for a 66?
Jeff
66 F100
55 Chevy Handyman
66 F100
55 Chevy Handyman
SD to Mass Air Conversion
Jeff66, Check out www.FordMuscle.com They have an article on SD to MAF conversion you may want to look at before looking for another harness. It may be cheaper to go thier way.
jeffs66 wrote:A friend of mine just bought a 91 Mustang LX with the HO engine.
i did that once on a 302, if he needs any help with anything,send me a PM.
