Electric fuel pumps
GDG
Post by GDG »
I put both an oil pressure switch and an inertia switch on my 64, both switches are connected to the ground wire of my relay. The oil pressure switch is open when there is no oil pressure. I got the inertia switch out of the CV that my frt suspension came from, the switch is above the left rear wheel house in the trunk. It has a reset button on it that you can also use as a theft deterant. I don't remember the part # of my Carter fuel pump but it was about $40 or $50.
Doug
jhewitt
Airtex 110-E84070 = Summit Racing Part Number ATX-E84070
Post by jhewitt »
Airtex Part Number 110-E84070
Free Flow Rate
72 gph
Maximum Pressure (psi)
5 psi
Inlet Size
3/8 in.
Inlet Quantity
One
Inlet Attachment
Nipple
Outlet Size
3/8 in.
Outlet Quantity
One
Outlet Attachment
Nipple
Griffin GA 1965 F100
Have 3, one daily driver others in different state of repair/disrepair
